| Home > Help Needed / General Tech Chat > Clutch Problems | |||||||
10th Feb, 2009 at 11:53:46pm
Right, after putting together an NA 998 to get on the road again I have run into some difficulty.
Gary's description is best |
10th Feb, 2009 at 11:57:58pm
11th Feb, 2009 at 12:15:19am
I'm not sure it is hydraulic Gavin. We have tried levering the clutch arm with a bar once the pedal is depressed. It doesn't move. It also looks like the shaft is travelling the full throw until the big nut hits the wok On 12th Nov, 2009 Paul S said:
11th Feb, 2009 at 12:20:46am
11th Feb, 2009 at 12:25:14am
On 11th Feb, 2009 Bat said:
Hi, Try backing the big nut off a bit
Cheers, Gavin :) as above what bat says ! other than that .......... your pressure plates GOOSED ! no balls left in it .. did you put the thrust washers in correctley ?
11th Feb, 2009 at 12:30:21am
We did initally have the big nut all the way off and had these symptoms.
11th Feb, 2009 at 12:42:21am
I might just get a hold of another clutch setup and try it. I'm being thrown by the fact that all the equipment.
11th Feb, 2009 at 11:10:58am
On 11th Feb, 2009 BENROSS said:
other than that .......... your pressure plates GOOSED ! no balls left in it .. did you put the thrust washers in correctley ? Ok lads My self an Gary where at this for a good wile on Monday evening and he spent most of yesterday at it, We have tried adjusting the trough out stop no difference. I then suggested that the whole clutch assembly might be moving up the crank taper to far so Gary totally dissembled the clutch and just fitted the centre spigot and pressure plate torque the big bolt. The primary was not pinched he was able to turn the crank and the primary stayed where it was. He then reassembled the clutch setup checking the clutch plate moved freely on the primary spline which it did. Fitted every thing up set the trough out as in the manual and still the problem. Am I right in saying there is only two possible ways the transmission is dragging ider the primary has been pinched to the crank by the clutch setup ? or the clutch is not reelecting fully ? I am now convinced its the pressure plate not clearing but why would a goosed pressure plate cause transmission drag surly it would cause clutch slip if anything ???? On 17th Feb, 2009 Rob H said:
32 Posts Member #: 2150 Member |
11th Feb, 2009 at 11:42:22am
Check the Clevis pins (all 3 of em) and the end of the clutch arm. If it's got a flat it'll need replacing or building up with weld and then reshaping. |
11th Feb, 2009 at 11:50:03am
check the ball and socket at the end of the clutch arm for wear ; is it the same cover that was on it before? |
11th Feb, 2009 at 12:07:33pm
Your not using a pre verto clutch arm are you?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Feb, 2009 at 12:25:27pm
Nope :(
On 11th Feb, 2009 MikeRace said:
Your not using a pre verto clutch arm are you?? On 17th Feb, 2009 Rob H said:
11th Feb, 2009 at 12:43:11pm
Hmm. I had similair problems when i had put a master cylinder in that had too bigger bore (im using remote resevoir type)
11th Feb, 2009 at 01:12:40pm
Two questions
11th Feb, 2009 at 01:16:16pm
Thanks everyone for the help so far. The release bearing is the one that came out of the car so it worked previously. The clutch arm wasn't removed from the wok so it is on the right way. All the eqiupment was used previously.
11th Feb, 2009 at 01:24:55pm
Could it be??...
In the 13's at last!.. Just |
11th Feb, 2009 at 01:37:16pm
If the arm moves the plunger until the locknuts hit the face of the housing, and you've already tried with the locknuts removed, remove the hydraulic cylinder and put a piece of close fitting tube over the arm and pull it backwards and forwards - you should easily "feel" all the free movement before the release bearing touches the tophat thing and then feel the resistance of the diaphragm spring - if your tube is long enough you should be able to release the pressure plate by hand and you will be able to tell (by feel) at which position of the arm this occurs and then check the hydraulics can replicate this.
11th Feb, 2009 at 01:38:35pm
I am running a verto setup but it is a possiblity that the arm is worn. I doubt its broken as spectacularly as that though 8-) I will check the clevis pins and arm tonight. They did all work before I blew the head gasket (twice) though On 12th Nov, 2009 Paul S said:
11th Feb, 2009 at 01:41:57pm
On 11th Feb, 2009 Rod S said:
If the arm moves the plunger until the locknuts hit the face of the housing, and you've already tried with the locknuts removed, remove the hydraulic cylinder and put a piece of close fitting tube over the arm and pull it backwards and forwards - you should easily "feel" all the free movement before the release bearing touches the tophat thing and then feel the resistance of the diaphragm spring - if your tube is long enough you should be able to release the pressure plate by hand and you will be able to tell (by feel) at which position of the arm this occurs and then check the hydraulics can replicate this. If the engine is in the car (with inner wings) you will need to bend a piece of tube to suit. Thanks Rod, I will try that. Fortunately I have a removeable front end. I've already had the inner timing plate off this week. Now I'm working at the other end! On 12th Nov, 2009 Paul S said:
16th Feb, 2009 at 11:38:21pm
Turns out it was a wanky pressure plate. Funnily enough it was OK last time the car ran. On 12th Nov, 2009 Paul S said:
17th Feb, 2009 at 01:39:24am
17th Feb, 2009 at 11:16:54am
I find that too. No one really listens these days On 26th Oct, 2004 TurboDave16v said:
17th Feb, 2009 at 12:23:07pm
On 11th Feb, 2009 PaulH said:
I am now convinced its the pressure plate not clearing but why would a goosed pressure plate cause transmission drag surly it would cause clutch slip if anything ???? I know I have been saying this since last week
17th Feb, 2009 at 12:23:11pm
dubble post Amature Edited by PaulH on 17th Feb, 2009. On 17th Feb, 2009 Rob H said:
17th Feb, 2009 at 01:05:52pm
did Sprocket say something? |
