| Home > Help Needed / General Tech Chat > Clutch issues: FIXED!! 05/06 | |||||||
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
12th May, 2009 at 11:09:48pm
I got my new engine running for the first time today, with very few issues. One thing I cant do is select gear whilst the engine is running.
Edited by stefaz on 5th Jun, 2009. On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
12th May, 2009 at 11:25:44pm
have a search for theoneeyedlizards posts.
12th May, 2009 at 11:28:43pm
Will be properly gutted if it is as this is a brand new build - only fired it up this afternoon On 23rd Oct, 2009 sim_ou_nao said:
12th May, 2009 at 11:28:47pm
whats the history of the engine etc clutch wise also ?
12th May, 2009 at 11:33:35pm
Brand new ultralight flywheel, greay diaphragm, new lightened backplate with the lugs machined as you suggested steve. On 23rd Oct, 2009 sim_ou_nao said:
13th May, 2009 at 12:09:01am
Ant I told you not to use marmite as your build paste, it's just not good practice! |
13th May, 2009 at 12:12:34am
ewwwww marmite!! i thought i told you it was a healthy dollop of hp On 23rd Oct, 2009 sim_ou_nao said:
13th May, 2009 at 09:53:38am
Don't mean to scare you, but after ripping mine apart, I found the thrusts were breaking up and had damaged the crank badly.
Edited by theoneeyedlizard on 13th May, 2009. In the 13's at last!.. Just |
13th May, 2009 at 10:08:15am
I'm quite worried about this on mine aswell!! But then im a paranoid/nervous wreck about everything on it at the moment haha.
13th May, 2009 at 10:13:00am
Thats what I was thinking Rich, will have to have a look if I get time this week On 23rd Oct, 2009 sim_ou_nao said:
13th May, 2009 at 10:11:58pm
Just had a quick go as I had a brainwave and thought it might just be stuck as it's been stood a while. tried pushing the clutch down with the engine at about 2000rpm and it just killed it On 23rd Oct, 2009 sim_ou_nao said:
22nd May, 2009 at 07:04:50pm
Stripped the clutch apart this afternoon and I had the plate in the correct way around.
23rd May, 2009 at 01:36:42pm
Have you measured the crank end-float?
23rd May, 2009 at 06:01:25pm
good call,
On 23rd May, 2009 theoneeyedlizard said:
23rd May, 2009 at 07:18:17pm
23rd May, 2009 at 08:46:57pm
Would them being put in back to front be causing something like this?
23rd May, 2009 at 09:23:25pm
well I was going to measure the backplate and double check first. if its the thrusts I will just have to strip it apart which means i defo wont driving it this year :( On 23rd Oct, 2009 sim_ou_nao said:
24th May, 2009 at 09:14:56am
Have you got the flywheel off? is the primary gear free to move on the crank, i say this as i had a similar problem, couldn't get a gear when the engine was running, turned out the spacer washer behind the primary was on the wrong way round. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
24th May, 2009 at 10:21:36pm
yeh primary gear spins easily enough by hand. could you not move your primary gear at all mate because this was my next thing to check On 23rd Oct, 2009 sim_ou_nao said:
25th May, 2009 at 09:24:43am
I could only just turn the primary when i stripped the clutch, I could easily turn it when i initially assembled the engine even though i put the washer on backward. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
25th May, 2009 at 09:52:45pm
hmmm might still be worth a check then. oh well down goes another gallon of oil On 23rd Oct, 2009 sim_ou_nao said:
29th May, 2009 at 02:38:58pm
The prize goes to chinlesswonder - have partially stripped the clutch side of the engine enough so I can tell it's on the wrong way...now just need to take the cover off properly and install the new thrust washer the right way round.
29th May, 2009 at 03:38:37pm
You should be ble to change that thrust washer without taking the transfer casing off I think. |
29th May, 2009 at 04:16:44pm
Yeah you can, just whip the seal out and pull the gear off. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
29th May, 2009 at 04:20:01pm
I told you it was that washer Ant!! |
