| Home > General Chat > Coil-over shocks... Options? | |||||||
24th Jul, 2009 at 01:48:10pm
I'm contemplating going 'coil overs' and am a little bit 'out of it' having not had a mini magazine for 2 years or so...
24th Jul, 2009 at 02:34:33pm
Now then.
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
24th Jul, 2009 at 03:10:04pm
I've got set of Gaz lowered coilovers on mine, on a 570kg car using the standard springs that come with the huddersfield kit.
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
24th Jul, 2009 at 04:41:40pm
i like the protech stuff, its a small place fun by the original engineer that did all the leda stuff 13pt adjustable, there only 15 miles from me if you want anything Dave
Edited by wolfie on 24th Jul, 2009. Crystal Sound Audio said:
24th Jul, 2009 at 05:13:02pm
On 24th Jul, 2009 wolfie said:
i like the protech stuff, its a small place fun by the original engineer that did all the leda stuff 13pt adjustable, there only 15 miles from me if you want anything Dave i have contacted them about a group buy, will wait for response http://www.protechshocks.co.uk/products.htm On 11th Feb, 2015 robert said:
628 Posts Member #: 1064 Formally Whyte_ben Horndean, Hampshire |
24th Jul, 2009 at 07:45:23pm
I drove up there and bought mine direct. He's a real nice guy and we both had a laugh at the shit quality of my old Gaz coilovers!
14 Posts Member #: 6698 Member Rotherham |
24th Jul, 2009 at 08:09:28pm
I had coilovers and beem axle on the back of my,n. Took them off last month because they bang when going over the smallest of pot holes. Also the ride hieght can,t be ajusted. I've tried gaz and spax. They are crap and maybe ok on track, wouldn,t use this setup on the road. Not value for money. www. |
24th Jul, 2009 at 08:22:07pm
Is that not suggesting that you have too firm a spring or too hard a damper?
24th Jul, 2009 at 09:28:15pm
On 24th Jul, 2009 minivan said:
I had coilovers and beem axle on the back of my,n. Took them off last month because they bang when going over the smallest of pot holes. Also the ride hieght can,t be ajusted. I've tried gaz and spax. They are crap and maybe ok on track, wouldn,t use this setup on the road. Not value for money. A bit of food for though: On 11th Jul, 2009 turbominivanman said:
Gents. Have an update to fitting my GAZ rear coilovers from Friday; On 10th Jul, 2009 turbominivanman said:
Just a thought but there are two lengths of coilovers to cater for standard ride height and lowered. My previous Spax coilovers smacked the crap out of the back suspension and I think its because I bought standard ride height coilovers in error when I should have bought lowered ones. My car is on 10's and could be considered low so its probably with good reason why I suffered what sounded like the dampers bottoming out over large bumps. I've just finished fitting the GAZ replacements to avoid the effect and the literature definitely says they're lowered jobs so when I take it back out on the raod I'm hoping to have cured the banging noise over large potholes. Will report tomorrow, weather permitting. Have now given the van a good workout with the new rear shocks. The lowered rear GAZ coilovers have completely eliminated my rear suspension banging / bottoming suffered with the previous Spax units, believed to be standard ride height jobs purchased in error. It's good news - and now a pleasure to drive. Each GAZ unit has 43 click adjustments on the hydraulic damper - I've got mine on the 18th click and the car's transformed. This is with 1.9 in ID progressive rate 80/125 lb springs and the beam adjusted to 0.5 deg negative rear camber and 3.2 mm toe-in. edit: 0.5 degrees negative camber, NOT positive. Cheers. Richard. Isambard Kingdom Brunel said:
24th Jul, 2009 at 10:39:49pm
i were finking of going coil overs simply to fit a rear beam to save weight.
24th Jul, 2009 at 11:32:07pm
I think any spax, gaz, avo etc shocks are good, and yes dont forget to get lowerd ones as all theyl do is bottom out?
![]() 646 Posts Member #: 1826 Post Whore Maldon Essex |
25th Jul, 2009 at 10:18:30am
I think I'm right in saying pro tech sell an "extra" lowered rear coilover set up too which maybe useful if running very low.
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
25th Jul, 2009 at 10:28:38am
What do people usually run for 13s? lowered or standard? Ive heard standard, but the only reason i can think of for that is the increased height of a 13 inch wheel? Anyone else have any thoughts? In boost we trust |
25th Jul, 2009 at 10:35:30am
the actual "height" of a 13 works out to be not that differet to a 10.
25th Jul, 2009 at 10:47:12am
Thats what i was thinking.
On 25th Jul, 2009 mini13 said:
the actual "height" of a 13 works out to be not that differet to a 10. depends on tyres obviously, Can they be changed from raised to lowered? Is it the length of the piston inside? In boost we trust |
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
25th Jul, 2009 at 10:12:32pm
Dave.
26th Jul, 2009 at 10:32:51am
If there is a group buy, id be interested. Not sure how postage would go to aus though lol. Probs more than the product like usual lol In boost we trust |
26th Jul, 2009 at 12:07:52pm
On 26th Jul, 2009 best_stig said:
If there is a group buy, id be interested. Not sure how postage would go to aus though lol. Probs more than the product like usual lol On 11th Feb, 2015 robert said:
26th Jul, 2009 at 12:53:11pm
Just dont use the same ones as Barrichello.
I seriously doubt it! |
614 Posts Member #: 2153 Post Whore kings langley |
26th Jul, 2009 at 01:03:36pm
i'd be keen on a group buy too, had spax in the past but the bracketry was rubbishand didnt allow you to run the car low, have to cut chunks out for clearence
26th Jul, 2009 at 02:29:49pm
The protech stuff looks good in many ways. The rear mount offset unit looks very well engineered.
26th Jul, 2009 at 02:31:18pm
So has anyone got an idea on approximate cost? In boost we trust |
26th Jul, 2009 at 03:06:49pm
Dave, i'll put some pics up of the rear offsets tomorrow sometime |
26th Jul, 2009 at 03:07:23pm
as if you all sorting a group buy though just after i bought mine!!! |
26th Jul, 2009 at 05:21:57pm
I'd be interested in a group buy too. On 7th Oct, 2010 5haneJ said:
