Home > Help Needed / General Tech Chat > further clutch issues
stefaz
Member #: 1656
stoke-on-trent
right, it's starting to get on my tits now. Everything is new, it's adjusted right and the system is bled with no air left in the lines.
Spec of the arrangement is u/l flywheel, grey diaphragm, race/rally plate. All the actuation bits are standard.
I built the clutch up made sure the drive straps were level when all torqued up both when mocked and when in situ.
My problem is that when the pedal is depressed the revs drop a tiny bit (circa 200 rpm) but I am unable to get any gears when the engine is running.
Does anyone have any ideas so I don't have to pull the engine again tomorrow as I'd rather not.
Help much appreciated gents and a mars bar for the winning answer...if I do need to take it apart I will make sure I take plenty of pictures
Ant
Nick
Member #: 154
Midlands
try starting the engine with it in first and your foot on the clutch. Just don't try it too many times and make sure you've got a clear runway *wink*
stefaz
Member #: 1656
stoke-on-trent
what are you thinking there nick? sticky diaphragm?
Nick
Member #: 154
Midlands
i'm sure we had similar issues with keans when we first built it, spent a good 2 days trying to get the clutch working even though it was all new and adjusted fully.
but yeah could just be something dragging/sticking, worth a try anyway.
Can i have a snickers if it works, not a massive fan of mars, lol *tongue*
Edited by Nick on 31st Aug, 2009.
stefaz
Member #: 1656
stoke-on-trent
haha if it works yes. i will have to see how brave I am tomorrow, busy road and short drive may make it interesting
stefaz
Member #: 1656
stoke-on-trent
after charging the battery all day to make sure it was nice and fresh I have just tried for about half an hour - it didn't work...sorry nick no snickers
Anyone mind giving me a quick list of clearances to check when I pull it apart at the weekend?
Turbo Shed
Member #: 30
Epsom, Surrey
have you tried dumping the clutch return spring? you really dont need it and it gives more travel on the clutch
stefaz
Member #: 1656
stoke-on-trent
lol yes I have mate
Turbo Shed
Member #: 30
Epsom, Surrey
ok, how about pumping the clutch pedal like mad and then holding it down with a lump of wood against the seat and leaving it over night? it bleeds the air out
stefaz
Member #: 1656
stoke-on-trent
i will give that a go. anything's worth a try if it saves me pulling it apart again
if the cutch slave cylinder is going all the way out and the grey diaphram is engaging
i would suggest a sticking clutch plate on the splines of the primary gear ?
this needs to be nice and free
can you get someone to press the pedal while you measure how much the release bearing plunger moves?
its not the ball broke of the clutch arm is it?
or maybe ..... the clutch plate is the wrong way around ?
stefaz
Member #: 1656
stoke-on-trent
clutch plate is deffo the right way around. I was paranoid about that when I put it all back last time. I will measure how far it moves tomorrow morning when it is light again
If it is the plate sticking on the primary gear what's the best way to sort this?
clean the splines on both with something like brake cleaner,
slide the plate on the primary, and slip it back and forth to check it moves smoothly, if its notchy get some 600 grit wet and dry in the grooves.
oh and I reckon on not putting lube on the splines.
Edited by Joe C on 1st Sep, 2009.
stefaz
Member #: 1656
stoke-on-trent
thats cool. i installed it dry last time. I'm sure some brake cleaner can go missing from work this week
pinkyandnobrain
Member #: 2588
Pretoria South Africa
What condition is the clutch arm ? Clevis pin ? Thrust bearing plunger ?
If these parts are too worn the slave cylinder goes to its full travel (stops against the cir-clip) but still doesnt release the clutch properly.
"Try to take over the world!"
stefaz
Member #: 1656
stoke-on-trent
It's all brand new mate - EVERYTHING lol.
You've clearly checked a lot. But now it is time to remove things. I suspect your primary gear is not spinning on the crank personally....
Nick
Member #: 154
Midlands
could be on the right track if its the floating bush and it hasn't got the chamfer on it to clear the crank radius thing.
have a check to see if the c clip is rubbing on the inside of the flywheel centre .
stefaz
Member #: 1656
stoke-on-trent
will have a look at the weekend when I get time to pull the engine and will make sure I take loads of pictures along the way.
What chamfer are you referring to nick?
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Think he means the ring thats chamfered on one side that goes behind the primary gear (pretty sure it goes behind the primary gear, dunno why ive forgotten!).
Althought I remember you checking this was the right way round when trying to sort this bastard out before hand.
Nick
Member #: 154
Midlands
i know i had an issue years ago when those floating primary bushes came out, they didn't have a chamfer on them to clear the radius on the crank that they sit against.
whether it'll be the casue of your problems i don't know but worth a look if you start stripping it down.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=305163
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=121150
stefaz
Member #: 1656
stoke-on-trent
Got thinking last night. could an overmachined backplate cause these issues?
Was just thinking that I might have had too much material removed...
