Home > Show Us Yours! > 1293 turbo with Mirage manifold
Flame Red
Member #: 6267
I'm building a 1293cc A series with the following spec:
rebored +20 thou, decked, steel centre main strap and modified for 11 stud head
Renault 5 Garrett T2 hybrid turbo on a Mirage manifold
Cast Omega pistons with 10cc dish
Avonbar Ph2 cam
Alloy vernier duplex timing gear
Ultralight flywheel
Lightened backplate with lugs machined down 1.5mm
Grey diaphram
SC drop gears
Fully rebuilt gearbox with X-pin diff and centre pick-up
3.1:1 final drive
Megajolt ignition
Pictures of the build so far:
DSC00824 by Matt4475, on Flickr
It took me 4 hours to remove the idler gear bearing race, In the end I welded a bolt into the race and tightened a nut down over a socket to draw it out.
DSC00825 by Matt4475, on Flickr
DSC00826 by Matt4475, on Flickr
Painted BMC green, I'm going for the retro look
DSC00827 by Matt4475, on Flickr
DSC00833 by Matt4475, on Flickr
DSC00829 by Matt4475, on Flickr
DSC00834 by Matt4475, on Flickr
DSC00857 by Matt4475, on Flickr
Sorry about the picture quality, my phone camera doesn't seem to work well with fluorescent lighting.
Matt
Edited by Flame Red on 11th Jul, 2017.
nice, like the green
looking good :)
green engines always look good!
looks like a quality build, everythings clean.
Looks nice, but real engines are black *wink*
What car is it going in??
they all end up black! *happy*
Flame Red
Member #: 6267
It's going in my 1990 Flame Red which is a bit of a rusty shed to be honest! mechanically it is very good though and I have spent a lot on it over the 4 years I've owned it. I'm just repairing the shell when necessary and when it gets too bad I'm going to reshell it.
A couple of pictures:
DSC00360 by Matt4475, on Flickr
DSC00639 by Matt4475, on Flickr
Sounds like a well though out spec, will give a powerful, reliable, driveable motor
i love engine build pics *happy* cant wait to see how it goes engine spec is very similar to mine :)
edit: what compressin ratio are you aiming for?
Edited by Brett on 9th Sep, 2009.
Flame Red
Member #: 6267
I think the CR is going to be about 8.25:1 with a 28cc head. I didn't so much aim for it as end up with it, it seems a little lower than the average but at least it should allow for plenty of boost. Hopefully it will still be ok off boost, I will just have to wait and see.
1293 sprite
Member #: 5449
Melton Mowbray
Nice project, good luck with it all *happy*
Specs almost the same as mine too.
1293 88.8hp 82.2ftlb
17.3 1/4 @ 78 mph
Naturally Aspirated (for now)
should be ok,
if it ends up a little sluggish of boost its no bigie to pull the head and get it skimmed.
1293 sprite
Member #: 5449
Melton Mowbray
What boost will you be running? What power are you expecting?
17.3 1/4 @ 78 mph
Flame Red
Member #: 6267
I don't really know, I was planning to run it in then see what worked well. I want it to be drivable but it's also tempting to try and get as much power as possible. Realistically I'm thinking 150hp would be very good once it's been run in and set up.
I currently have a NA 1275 with kent 286 cam so I think this will be a big improvement in drivability whatever.
hario
Member #: 2885
You just convinced me to go green block and head. I always KNEW red was faster and better but..
Where did you get the paint if you Dont mind, Ill check ebay in a miunute i think..
I like your golden vernier by the way! < Is that rude?
BEER *happy*
Edited by hario on 9th Sep, 2009.
looks really nice, just one worry and that's you seem to have a normal gearbox, so just take it easy from the traffic lights *wink*
what you want is some 10x5 100+ slotmags, it will finish the car....
i also happen to have some for sale lol *wink*
looking good
p
Flame Red
Member #: 6267
The paint is the Classic Car Colours BMC Green, Mini Spares, Moss, Frost etc all sell it. I used the brush on for the block and the spray for the rocker and timing covers, they both seem to give an excellent finish but I was really impressed with the spray.
It is indeed a standard gearbox with the exception of the diff and drop gears. Is there a rough figure of HP or torque at which they are know to fail? I have searched but I couldn't find much.
Thanks for the suggestion Paul but I have a set of 10x6 Cosmic wheels. I just can't bring myself to spend the money on S brakes or 4 pots.
Matt
is that the trigger wheels bolt on crank wheel?
Flame Red
Member #: 6267
Yes.
Flame Red
Member #: 6267
I've made a bit of progress over the last few days, I've made an oil return and an actuator bracket. The actuator bracket mounts on the exhaust flange of the turbo, I was going to make something similar to Nic's but I found it limited access to the manifold nuts too much.
I've started mounting a radiator from a Nova, it seems to fill the space quite well but at the moment the starter, alternator, bonnet catch and cold air feed don't fit, it looks as though I will be able to keep the external bonnet release though.
DSC00860 by Matt4475, on Flickr
Flame Red
Member #: 6267
I got my backplate bake from having 1.5mm taken off so the clutch is now on, almost looks like a complete engine now. I've just got an old head on there for the moment so I can trial fit the turbo and make some brackets.
DSC00861 by Matt4475, on Flickr
I've also taken the old engine out, made some brackets for the radiator, wired up the megajolt and the fuel pump relay.
DSC00864 by Matt4475, on Flickr
I've got a Matiz alternator as the old one was very close to the radiator. I took about 4.2mm off the water pump lug to get it to line up and made a spacer for the other side. I also made something to join up with the old adjustable bracket, it doesn't look too pretty and it's not the perfect solution but I think it should work, I want to make sure it clears the radiator before I spend time making something decent. I tried to measure how much clearance I had gained with this alternator, it looks like it's only about 15mm.
DSC00866 by Matt4475, on Flickr
DSC00867 by Matt4475, on Flickr
Also this arrived today from Benross
DSC00865 by Matt4475, on Flickr
It didn't stay looking like that for long, it's already had 2 coats of BMC green. It will be going on the engine as soon as the paint is dry.
Ah the old red undercoat trick. Keeps the 10 banana power gains of the red paint.
Matt
matt you might find this thread interesting :)..
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=168594
i tipped a litre of red inside my motor as i forgot to paint the outside,should do the trick....
Ben.
Member #: 1064
Formally Whyte_ben
Horndean, Hampshire
Looking good mate.
Not sure that newspaper headgasket will last long though!
Build Thread Click Here
Users viewing this thread: none. (+ 2 Guests)   Next ->
