Home > Help Needed / General Tech Chat > Undercrown Oil Jets 1380
Quick Q for a future build.
Anyone fitted oil jets to a 1380? Can it be done? Is there enough room?
Also which jets are best BMW or Zetec?
do a search......lol
i recall bmw ones being used alot
use the search button *wink*
Get bent. I've searched but can't find anyone with them on a 1380!
pmsl,
YEP I'VE GOT THEM ON A 1380 oopsd caps...
I'll have a natter with the machine shop when I pick the crank up this aft if you want
Am I right in thinking the basic principle is:
make a flat spot next ot the bore
drill and tap mounting holes
drill feeds into the oil gallories
You forgot the bit where you have to dig out the broken drill bit *happy*
You can remove one of those steps if using the bimmer jets. *wink*
Edited by theoneeyedlizard on 22nd Oct, 2009.
Here's me thinking you were an experienced engineer with quality tools Paul *hehe!*
i seeeem to remember sprocket covering this in his build thread, one has a ball bearing on a spring that shuts off the flow at low oil pressure
Thanks mini13!
On 22nd Oct, 2009 mini13 said:
pmsl,
You offered to loan me the tools for the bimmer jets a while back actually. I may take you up on the offer if its still valid.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5512
http://www.turbo-mini.com/44648/23109.html
the first one is a good read :)
advantage998
Member #: 1840
Kings Lynn, Norfolk
Was gonna make a post about this myself. Just ordered the bimmer jets today. (Part no. 11 11 1 739 907 at £38.41 incl VAT incase you needed it).
How do people spot face the block? Can you use a milling machine cutter in a pillar drill? If so what type of cutter is required?
Already read those brett. Just wanted to make sure there was enough material to get them in there with a 1380
Ah, but you only do the last hole with a pistol drill and you have to judge the angle to hit the main gallery. Slightly off centre and the drill bit will snag as it breaks through. If you are not ready for it, the drill bit can break as it did with me.
Luckily I was able to push the broken bit back out from the gallery end :)
*happy*
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Beemer jets definately look neater and slightly easier to fit. The oil supply and fixture are the same so there is one less step to fit them. I (stood there whilst Paul) fitted Zetec jets to my small bore and it was a pain in the hole
On 30th Apr, 2010 Rod S said:
Gary's description is best
no probs as long as i can find them! *happy*
Thanks mini13!
pmsl,
id just use a pillar drill as long as its up to the job
you want some of these:
http://www.axminster.co.uk/product.asp?pf_...&sfile=1&jump=0
and depending on the taper (MT2 MT3 etc) some of these jobbies to hold them in:
http://www.axminster.co.uk/product.asp?pf_...sfile=1&jump=44
ive got quite a beefy pilar drill, so can do a fair bit of non precision stuff with it, got a bit of info on this thread if it helps:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=255327
advantage998
Member #: 1840
Kings Lynn, Norfolk
Thanks for the link to the bits i need, never ventured into milling. My pillar drill looks identical to yours except floor mounted so hopefully i'll get on ok.
Those little drill bits are a bastard. I set the clutch on the drill nearly as low as it could go and took roughly 5 min per hole to prevent the same catastrophy. This was after reading your experiences Paul:)
Ham fisted fuckers!
What?! you mean you have never broken a drill bit in a hole?
nope, never.
Clearly not drilled as many holes in a block as I have *hehe!* Your time will come *happy*
