Home > Help Needed / General Tech Chat > A+ Cranks.
Si P
Member #: 912
North Yorkshire
Right as some of you are aware. I’ve had a bit of an oil pressure issue with my motor. Starting of fine 65psi then falling to about 20-15 after about 5 mins.
So I've pulled it apart and everything is in order apart from the crank. It looks like its done about 150.000 miles. When it's actually only done about 350 slow miles.
The mains are nearly through the white metal. and the crank has worn to the same extent. It was 10 thuo under to start with. but now it would require the max 40 thro just to get it useable again.
There are no signs of excess heat or contamination. The cam, engine bores and oil pump all look fine to.
So can it just be that with a relative high compression ratio and stock crank that’s it worn itself out super fast.
The engine turn over fine when built and all new components were used. I still have all the blue print info of the build.
Crank was a stock MG metro 1275 A+ item. with just a regrind. The crank has had no other treatment.
Are these cranks made out of fudge...?
I'll post some pics later for all to see.
Si
Si, you say down to the bearing backing, i take it the journals are badly scored , if this is the case it was debris and shite in the oil ways [ iron fillings] that has done the damage, snowball effect,
carl
high comp will not do any damage
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Would incorrect clearances to start with cause this?
On 19th Jan, 2010 wil_h said:
Si P
Member #: 912
North Yorkshire
Carl,
I must get some pics up for you. But everything looks clean. Not like its picked anything up. The crank has a mirror image of the shells worn into it. No scoring or heat. The oil ways in the crank are clear to. But I will look deeper to see what I can find.
You'd think the pump would tell the story but on first inspection look fine.
Thought at first that it might be bent, and put extra load on onto the bearings.
But I can say hand on heart that it was'nt when it went in.
Si
What shells are they?
Where did they come from?
Oil gallery core plugs fitted too deep?
Si P
Member #: 912
North Yorkshire
Paul, I'll check my notes..
Oil gallery core plugs were drilled and taped with new threaded plugs. But will check that area to.
Si
is this mains or big ends, or both?
carl
On 30th Dec, 2009 Si P said:
Carl,
Si
Si P
Member #: 912
North Yorkshire
Mains Carl,
Big ends are bad but know were near as bad as the mains.
Si
Pictures!!
pictures of the oil gallery plugs too
Edited by Sprocket on 30th Dec, 2009.
turbo hogster
Member #: 178
stowmaket suffolk
could be down to the regrind an depends who done it.
i still use a bog standard one with no regrind at the moment.
several race engine builders who i spoke to said check on a lathe with a dti and check journels if with in tolerence then leave alone.
mine had less than 1 thou discrepancy so i left alone and all my cranks have neen fine. sometimes the grinders just bang them out with out properly checking the clearances.
one guy sent a crank of for a regrind to a reputal machine shop and came back worse than he sent in the deflaction check on the mains so always be carefull.
Si P
Member #: 912
North Yorkshire
Crank was done by Drakes in Bradford.
Who are very well know and of good reputation.
I promise pics tomorrow. and pics of plugs for Sprocket.
Si
Edited by Si P on 30th Dec, 2009.
i don't think its possible to knock the standard gallery bungs in too far, they should hit a shoulder before getting anywhere near a takeoff.
carl
Si
carl
Carl, they are not standard plugs
Si P
Member #: 912
North Yorkshire
Thats whats funny,
I thought if it was a shortage of oil the crank would of started to dis colour. or even spin a bearing. But theres no sign of heat build up.
Si
If anything should have spun a bearing, it should have been mine lol
Si P
Member #: 912
North Yorkshire
Just shows how stubborn these little engines are.
I always fit allen plugs to the oil ways, and on one side of the block, you need to be very careful not to fit a too long one. This WILL decrease/hinder the oil flow.
Did you plastigage the crank when fitting?
Si P
Member #: 912
North Yorkshire
Heres the pics at last.
What do you think.?
Blown Crank.
Rear Main Crank Journal.
Rear main Bearing Shell
Centre Main Crank Journal
Centre Main Bearing Shell
Front Main Bearing Shell
And as Vegard mentioned above. Heres the plugs ( Sprocket ).
Allen Screw Gallery Plug
Gallery Plug Length
O and it just goes to show how long it was when I built it. Its actually a turbo crank.
Si
That is contamination im afraid. But in all honesty, they dont look that bad.
Did you plastigauge the clearancies before you assembled it?
Edited by Sprocket on 9th Jan, 2010.
kal14
Member #: 7915
Be careful to buy anything from me. You have been warned.
westmidlands
Si
hi mate saw same prob twice before if cam bearings are worn it drops preasure and will do mains over few miles . and other reason i found was an engine was rebuilt and the oil pump gasket was fitted back to front , it starts with preasure then drops of gradualy after few min running if you rev it up and keep it steady it will slowly go up then drop of again . and o ring between block and box or pickup pipe or gasket . john 07984248020
This is what I thought you were talking about
Si P
Member #: 912
North Yorkshire
No, not that bad Sprocket. But worn in super quick time.
When you say contamination what do you actually mean? Foreign bodies or oil break down.
Because I've not found any real muck in the box or block ( oil galleries ) or any sign of anything broken.
No Plastigauge used at the time of rebuild. Just old school measurement techniques.
I have spent an hour examining the block and oil ways etc and have measured the rear main oil feed drilling in the block its 14mm from the block end face as per normal pre A+ blocks, however when I come to check the drilling by pushing a flexible tie wrap up from the rear main bearing its difficult to do. Almost as if there is a miss match with the feed hole's?? I’m not sure if this is because of the relief valve drilling (where the ball and spring is located) but I have another block which I will measure for a back to back comparison of this feature. The other main oil gallery to main bearing holes are perfectly clear both on the centre main and front journals???.
The search goes on. I don't just want to rebuild it and screw up yet another crank.
Si
You can see particulate material embeded in the bearing surface and light scoring marks indicating that debris has entered the bearing at high speed. This could be from machining processes on either the block or the crank.
I spend at least an hour just cleaning the oil galleries with tube brushes, paraffin, parafin gun and compressed air until the parafin runs clean.
What other method is there to measure the clearance in bearing journals other than the age old plastiguage?
Also, please clarify one of your initial statements. "Starting of fine 65psi then falling to about 20-15 after about 5 mins" was this from cold? This could indicate that the engine clearancies were large to begin with, oil pressure dropping as the oil viscosity drops as it heats up.
Also, if that is a Pukka Turbo crank it will be hardened, and would not wear so much to require another 0.030" grind to clean it up. Having said that, the 0.010" grind might have removed the hardened surface.
The failure I had even though the bearing clearance was measurable in mm oil pressure was still good even at idle, which is why I was initialy unsure what the problem was. I am using a trubo capacity pump though.
Also have a look at the document attached
Jason G
Member #: 1459
En-suite user
Braintree, Essex
While its in bits, might as well throw another oil pump in as a precaution.
