Home > Help Needed / General Tech Chat > Electric water pumps
ant
Member #: 8372
wickford , essex
right guys well ive had a little search and read through some of the probems some people faced when fitting these , im going to be using a cinquento front mounted rad in the car , and want to put an electric pump on , whats best really ?
i see some places like demon tweeks and europa sell electric water pumps but they are fairly dear , how do people get on with the renult / vauxhall ones ? and how do we reckon is the best way to plumb them in ?
also as a little tag question , what fans have people fitted to the cinquento rads ? im thinking of trying to source a little pair of motorcycle ones ? :)
thanks in advance
ant
Kean
Member #: 341
aka T2clubby
South Staffs
I used two Suzuki GXSR fans on mine, although its a metro rad.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
I think you will struggle to keep the engine cool in traffic with the small "water movers". They are likethe KAD ones with the main idea being to keep water circulating after shut doen and reduce hp losses. The flow rates are quite low, although there is not data to say what the performance of the mechanical pump is. TurboDave was using one with a mechanical pump fitted too. I think he planned on removing the mechanical pump but it wasn't documented.
On 30th Apr, 2010 Rod S said:
Gary's description is best
I fitted a Meziere pump to mine and works a treat with a cinquento rad.
GaryOS
Member #: 2810
Dublin, Ireland
And I have a Meziere pump (WP-136S) sitting in my kitchen looking pretty. I'm sure it will work well one day
Arnoud
Member #: 1085
Netherlands
any pics of that please?:) I've been looking at the Davies Craig one sofar. Is there a flow control device as well, or is it running the same rpm all the time?
1963 Cooper
1975 Pick Up
GaryOS
Member #: 2810
Dublin, Ireland
I will be running mine with a Davis Craig pump controller to vary voltage (and therefore flow rate) dependant on temp. I think Mattys is on/off.
I'll post pics when I get home later
Im using a thermostat to control the temps, saves expense, additional wiring and added complictation. *wink*
GaryOS
Member #: 2810
Dublin, Ireland
It sure does. I went for the controller as Phil had it going cheap. It also meant I could keep the pipework a bit neater. P.S. if you use a 'stat it has to be a capillary type.
I used to use a Renault water mover on the rear engine in my twinnie, it worked perfectly, even though it was moving water from one end of the car to the other
GaryOS
Member #: 2810
Dublin, Ireland
I think we need to know the intended use for the car before we say if something is suitable. I'm sure the water "movers" would be no use in traffic
ant
Member #: 8372
wickford , essex
ok , thanks for the help so far guys :) the car will be a fast road/trackday toy , so yeah it needs to be able to sit in traffic really :)
thanks
AWDmoke
Member #: 713
Western Australia
EWPs are like thermo fans - they run independant of engine speed, based only on need (temperature).
So they are MORE suited to traffic than a belt driven pump. The flow of the belt driven pump at idle is four fifths of fuck all, but an electric pump can run at full flow if needed.
On 24th Dec, 2008 Nic said:
jpboost
Member #: 29
Croydon
When I was looking into this recently, I had a long chat with KAD about their pumps. They have had no problems with them & have been using them for many years.
I can't see why 'traffic' would be more difficult situation than a full race situation.
Obviously you get less airflow in traffic, but surely this is more a radiator/fan issue than it is a waterpump issue.
Too many projects!
ant
Member #: 8372
wickford , essex
okay thanks for your help guys , i might try and get my hands on a KAD pump , if that fails then look into a renult pump *wink*
thanks guys :)
ant
Member #: 8372
wickford , essex
jeeeee just seen the price of the KAD pumps *happy* there went that idea , anyone know the part number or more details of the renault pumps please ?
thanks
NZMED1293
Member #: 8924
New Zealand
DAVIES CRAIG ELECTRIC WATER PUMP AND CONTROLLER. BEST ON THE MARKET!!!
NEW ZEALAND MIGLIA SPEC ROAD LEGAL TURBO MINI BUILD THREAD >>>
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=363477
PaulH
Member #: 2340
Dublin Ireland
NO THERE NOT
On 17th Feb, 2009 Rob H said:
GaryOS
Member #: 2810
Dublin, Ireland
On 25th May, 2010 PaulH said:
NO THERE NOT
haha, well answered
NZMED1293
Member #: 8924
New Zealand
they are in my part of the world.. shall i say " hemisphere " ...
Anton
Member #: 764
Staffordshire
I wish you would fix your keyboard...
NZMED1293
Member #: 8924
New Zealand
lol yeh fauly button. damn thing.
thanks
mate have a look at corley conversions. He sells them to kad evey week and it cost me £105
thanks
Oooo! Nice tip.
I may be making a phone call unless I can find a suitable donar in the scrap yard.
thanks
Oooo! Nice tip.
that tip is just between me and you lol
Edited by madmk1 on 25th May, 2010.
