| Home > Help Needed / General Tech Chat > What turbo would you want to use instead of the T2 on Mirage setup? | |||||||
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
14th Jun, 2010 at 04:19:45pm
Hi all.
14th Jun, 2010 at 04:43:33pm
GT1752 :) |
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
14th Jun, 2010 at 04:50:02pm
also out of interest i sent you an email asking about supply of the exhaust side part. supplier issues aside is there any chance you can get back to us? |
14th Jun, 2010 at 05:41:11pm
gt17 Crystal Sound Audio said:
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
14th Jun, 2010 at 06:59:46pm
i managed to squeeze a T25 in from a saab 9000 cse, but needed to take a few mm off the block,if the flange was at more of an angle it would have gone in nice, On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
14th Jun, 2010 at 08:03:22pm
Sorry Taz,
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
14th Jun, 2010 at 08:12:40pm
GT1752, Im waiting for a T2 manifold from you, but would sell my T2 if the GT17 was an option. Class C 3rd Place Avon 2011 14.18 @101mph |
14th Jun, 2010 at 10:18:38pm
no worries pm'd
On 14th Jun, 2010 Mirage said:
Sorry Taz, Which part do you want? Tmain manifold? |
14th Jun, 2010 at 10:40:57pm
I think the GT17 will be a popular choice, but it is a tight fit with no bulkhead. Not even sure anyone has managed it.
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
16th Jun, 2010 at 07:43:17am
GT15 ? "So wat we gonna do tonight Brain?"
16th Jun, 2010 at 09:59:42am
what about some manifolds for cars with bulkhead box's as well? or maybe one for the k head turbo's? as a thought if it were me i would say gt17 or the gt20 range :) Drives
44 Posts Member #: 8820 Member alrewas, staffordshire uk de13 7bs |
16th Jun, 2010 at 10:37:26am
gt1752. i have a couple in bits, if you want to borrow them i can post them to you or something of that nature. so you can piece it together and get an idea of the sizes?
Edited by d1k1m4y on 16th Jun, 2010. |
30th Jun, 2010 at 10:12:17am
Hi Guys,
30th Jun, 2010 at 10:21:11am
saab's i belive, renault leguna dci's only the top power has the good one, some van;s Drives
30th Jun, 2010 at 10:45:06am
The correct GT17 is actually quite rare, fitted to the Saab 95 Aero, but only certain models. Search on here on how tight the GT17 is to fit though.
![]() 825 Posts Member #: 2208 Post Whore Essex |
30th Jun, 2010 at 10:50:21am
vnt 25?
30th Jun, 2010 at 11:08:42am
I thought that the 1752 was fitted to most Saab 93 and 95s other than the aeros which have TD04s. In the 13's at last!.. Just |
30th Jun, 2010 at 11:13:15am
Sorry getting my aeros confused.
30th Jun, 2010 at 12:49:08pm
Thanks guys for the info.
71 Posts Member #: 7907 Advanced Member Thame, Oxfordshire. |
30th Jun, 2010 at 06:37:44pm
how about the GT 15 dont know if its any smaller than the 17, for a better fit, i think its got the same A/R's as the renualt 5 T2 but i have no idea what cars would have them on. |
617 Posts Member #: 6558 Post Whore Pueblo, Colorado, USA |
30th Jun, 2010 at 07:03:48pm
gt 12 and gt15 have the same triangular flange, but I'm not sure if all are the same, as some gt15 have a square flange. I'm thinking a gt12 on my mini compounded later to a gt15 or gt17. |
30th Jun, 2010 at 07:23:18pm
bmw deisels, merc sprinters but will require a bulkhead box
On 30th Jun, 2010 wintersurferuk said:
vnt 25? Drives
30th Jun, 2010 at 09:15:42pm
Comparing new to old. It really is amazing how the modern wheels the size of a 10p, outperform the old T-series which look about 3x the size lol 9.85 @ 145mph
30th Jun, 2010 at 09:37:15pm
a fucking massive bulkhead box! On 30th Jun, 2010 Paul R said:
bmw deisels, merc sprinters but will require a bulkhead box On 30th Jun, 2010 wintersurferuk said: vnt 25? On 28th Aug, 2011 Kean said:
30th Jun, 2010 at 10:18:01pm
On 30th Jun, 2010 miniswordsman said:
gt 12 and gt15 have the same triangular flange, but I'm not sure if all are the same, as some gt15 have a square flange. I'm thinking a gt12 on my mini compounded later to a gt15 or gt17. compounding compressors of two different air flows wont work very well. two the same will in theory will double the pressure ratio of a single compressor. A compressor will 'lift' the pressure say, two bar for arguments sake, from inlet pressure. If the inlet pressure of the secondary compressor is 2 bar, that means the discharge will now be 4 bar. the primary compressor inlet pressure is zero (guage) and discharges at 2 bar into the inlet of the secondary compressor. air flow, pressure ratio, and compressor efficiency will still be the same on both compressors, but discharge at a higher pressure on the secondary compressor, Two compressors in parallel will double air flow, but will only be able to achieve half the overall pressure ratio of two compressors in series (compound) On 26th Oct, 2004 TurboDave16v said:
