| Home > Technical Chat > N/A MG Metro cam profile | |||||||
![]() 562 Posts Member #: 9285 Post Whore Oxfordshire |
27th Jan, 2012 at 07:13:32pm
Just wondering if there is a manufacturer that make a cam with the same profile as the on mentioned in the title?
27th Jan, 2012 at 07:24:40pm
Kent do, under the title KC500 I believe. |
27th Jan, 2012 at 07:25:16pm
There is a Kent cam thats either the same or very close, think it may be a 500? On 26th Jan, 2012 Tom Fenton said:
27th Jan, 2012 at 10:03:54pm
Thanks chaps. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=454802
28th Jan, 2012 at 12:14:45am
The sw 05, kent 266 and the MG na can shaft profiles are virtually identical when you compare there lobe profiles. Own the day
28th Jan, 2012 at 10:32:50am
On 28th Jan, 2012 Mr Joshua said:
The sw 05, kent 266 and the MG na can shaft profiles are virtually identical when you compare there lobe profiles. No they are not, but then it depends on what you mean by 'virtually' On 26th Oct, 2004 TurboDave16v said:
28th Jan, 2012 at 10:52:54am
MG
28th Jan, 2012 at 11:03:44am
and while i'm looking at the data
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
28th Jan, 2012 at 11:04:07am
So as a basic spec/theory, what figures are you looking for in the cam specs on paper to highlight it for possible turbo use? one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
28th Jan, 2012 at 11:05:27am
Many thanks for that Colin, very illuminating. I have a MG NA cam in the car ATM and am building another engine with a Kent 266 - it will be interesting to see if I can detect any difference. |
28th Jan, 2012 at 11:13:55am
On 28th Jan, 2012 Sprocket said:
MG Inlet 252 degrees, LCA 110 degrees, lift 6.68mm Exhaust 268 degrees, LCA 105 degrees, lift 6.68mm LSA 107.5 degrees Overlap 45 degrees KC500 Inlet 252 degrees, LCA 110 degrees, lift 6.7mm Exhaust 268 degrees, LCA 105 degrees, lift 6.7mm LSA 107.5 degres Overlap 45 degrees SW5 Inlet 244 degrees, LCA 106 degrees, lift 7.14mm Exhaust 244 degrees, LCA 110 degrees, lift 7.14mm LSA 108 degrees Overlap 28 degrees MD266 Inlet 260 degrees, LCA 106 degrees, lift 6.68mm Exhaust 270 degrees, LCA 106 degrees, lift 6.81mm LSA 106 degrees Overlap 53 degrees colin , have you checked to see if all those numbers quoted are measured at the same lift ,and whether its at the lobe or the valve ,and if at the valve which ratio rocker its with ,to make sure they are all truly comparable . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th Jan, 2012 at 12:55:46pm
lobe lift
28th Jan, 2012 at 01:47:27pm
The problem is that none of the cams that I've measured actually relate to the quoted values.
28th Jan, 2012 at 02:30:12pm
lobe lift The KC500, and the MD266 checked with data on the respective web site, and cross refferenced with AC Dodd's information on the ML Motorsorts and double checked on RB racing cam calculator. Swiftunes website looks as though its down at the moment. at what lobe lift are the durations checked ,eg, is everyone using the same lift point to start and stop measuring ? i have found this can vary between manufacturers ,and make a big diff . eg 0.001..0.004,..0.005 even 0.1mm , i have seen a variety of test points. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th Jan, 2012 at 02:38:51pm
yep, 50thou lift can be 50 from the base circle... or from the tappet seting height.. or at the valve... etc On 28th Aug, 2011 Kean said:
28th Jan, 2012 at 03:48:13pm
This 50 thou measuring thing came about in the US during the 80s when most cars had hydraulic tappets. It seems to have been adapted throughout the world as the defacto standard, but it was originally concieved as the "give" in the hydraulic tappets before they lifted the valve.
28th Jan, 2012 at 03:50:37pm
a useful measurement though, as long as your taking the measurements from the same datum. On 28th Aug, 2011 Kean said:
28th Jan, 2012 at 04:07:19pm
True.
28th Jan, 2012 at 04:45:07pm
Checking height 0.015" Edit** I think Kent's checking height is around 0.0125" judging by Keith Dodd's figures EDIT again**** Nope, kent state 0.016" checking height at the valve, so 0.0125" is at the lobe. Either way, AC Dodds info does seam to at least compare data accurately.
28th Jan, 2012 at 05:24:56pm
Ha ha...... you have to use a calculator to work out duration and LCA.
28th Jan, 2012 at 05:32:43pm
I don't have the stamina, I was brought up in an age of the calculator On 26th Oct, 2004 TurboDave16v said:
28th Jan, 2012 at 07:04:20pm
I'm thinking of using the 274 next time the engine is out, just because I have been recommended a cam with 112 lca. I run a supercharger and I don't care the TB is on the wrong side.
28th Jan, 2012 at 07:08:41pm
I've got a 274 for mine Graham. On 11th Feb, 2015 robert said:
28th Jan, 2012 at 07:27:45pm
274 injection sounds tempting to me too. If something is worth doing, it's worth doing half of. |
28th Jan, 2012 at 08:55:57pm
Sorry that my earlier post was a massive generalization but I used the same path for checking my figures. The reason I made the generalization was that on inputting the figures I had for a base cam profile it spat out figures that were somewhere between the sw 05 and kent 266.
Edited by Mr Joshua on 28th Jan, 2012. Own the day
