Home > Help Needed / General Tech Chat > quick lambda sensor question
Nick
Member #: 154
Midlands
I've decided to get a lambda fitted into my exhaust for when my car gets back on the road. I've found a bloke selling universal ones ebay, you reckon they'll be ok for the job?
here's the link http://search.ebay.co.uk/_W0QQsassZecuworld
just need to know which one to get... 1/2/3/4 wires???
Nick :)
Doodmeister
Member #: 149
Alberta, Canada
This would be a better choice
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...7976704082&rd=1
AllanMcD
Member #: 414
Dalbeattie Scotland
1 wire dosnt have a heater fitted so it is slower to respond when cold I think it is just the 3 and 4 that have the heater fitted but it is easy to find inf on the web the wiring is simple.
http://www.rabdunn.co.uk/
I use a 4 wire sensor, works well for me
Nick
Member #: 154
Midlands
karl that looks perfect dude, cheers :)
I remember when those things were £250 or more a few years back!
Ain't advances in technology/copying what someone else did originally great! Absolutely no excuse not to have one!
pot_dan
Member #: 326
bradford, west yorks
the link bud posted, i have the 4 wire one, came the other day, verry good service from him and the sensor looks ok, with instructions etc, not fitted yet tho:)
Dan
Mike
Member #: 107
Sunny Sussex
do u really need a heated one if its only about a foot from the turbo elbow? surely thats hot enought?
i often wonder if you need a heated one if you always let the car warm up before driving it
Nick
Member #: 154
Midlands
i wouldnt have thought so.
mines got to go in the downpipe anyway as the rest of my exhaust is stainless and i can only weld mild with the mig at my house.
pot_dan
Member #: 326
i bought the heated one just becouse i could, lol
i wanted it to work more or less straight away tho i do now see what you mean about not 'driving' it when its cold anyway.
mine will be int he down pipe i have spoke to richard at mirage and he said he will weld my nut in for me*happy*
Dan
On 16/06/2005 10:57:35 mini1071s said:
So is the 4 wire one from the first link for £22 ok to use with a seperate gauge? Any way of finding out which wires go where? Going to use with the win SU program to get the needle right.
Good idea in theory, but from when I have used WinSU before, I doubt you will get anywhere near the right needle, as it only lists the standard ones. To get the right one for turbo use most people start with a standard one and then file it to suit.
the two white wires are for the heater element, one is earth, the other live (doens't matter which)
now your half way there, I can tell you the other two when I get home on weekend
you looked yet jim?
is you gauge a volt meter or something more elabrate ?
any one got any web links to any companys selling a decent gauge??? for a decent price
thanks
Edited by BENROSS on 17th Jun, 2005.
jamesfawcett
Member #: 218
Bingley, West Yorkshire
sorry just a quick question do i need a fuse to the lambda sensor heater +12v?
Lambda is (I'm pretty sure) the Grey is -ve, the black +ve
jamesfawcett
Member #: 218
im going to wire mine up with...
one white heater wire to +ve
one white heater to earth
grey wire earth to earth
black to my guage
is that ok? Do i need fuses inline iwth any of them?
I'd put a fuse in the heater circuit... Try a 10amp blade fuse, if it blows go up a size *wink*
From my experience, to get a true reading all the time, get the heated one. When the element cools off at idle and just abouve it will read rich when its not. It took me ages to figure this out on my SPI and it was the relay that was boloxed, heard it click when energised, there was 12volts there, but nothing out.
Trust me, non heated Lambdas will at some point give you a duff reading even with it on the elbow of the turbo
I've got the 4 wire one as well from that ebay bloke. came quickly with instructions of what wire goes where. although its a while since i looked at it! need to get a boss welded on really!!
jamesfawcett
Member #: 218
you gonna get it welded in same place as me iain or you gonna get it down by the gear selector?
dont know yet *smiley*
Star Mag
Member #: 375
Leicestershire
heck this website out i got a meter from here at christmas, Not using it at the minute but a freind of mine is using his. Its will show Afr, Boost Pressure, Rpm etc etc
http://wbo2.com/
Anton
Member #: 764
Staffordshire
i just grabbed a 2nd hand one from an MGF off ebay....
its not heated yet but works fine with my autoguage meter.
might try and heat it tho, as you explained it does read rich at idle somtimes.
check the thread for its mounting too, i had to find a nut with a strange thread for mine for fit too.
TurboHarry
Member #: 115
Austria, near Vienna
Hi!
Feebleuk's wiring is ok!
Nonheated sensors show bshit when cold; would never fit a one wire sensor again.
I am selling fuel mixture kits with calibrated LED display, welding bung and new 3 wire Bosch sensor for 70 pounds + postage.
Harry
Bimmer Twinky headed and turboed A-Series:
http://www.minifreunde.at/harry/projects.htm
