Home > For Sale > Mini Turbo Inlet Temperature Sensor
http://watercooling.co.uk
ive jsut been playing with mine actually!
That's got to be a strong contender for "Best Quote Ever!"
PMSL
damn it!!!
im normally careful with my inuendos
Nick
Member #: 154
Midlands
you managed to get yours working properly Nic? gave up on mine but would be nice to get it working properly.
not yet, but im planning on it! ill keep you posted
Badger
Member #: 1488
Sounds so wrong to me *tongue*
There is no sense crying over every mistake- you just keep on trying til you run out of cake.
We should have a hall of fame for these quotes *wink*
As I've said before there's never a day goes by that I don't find a post that amuses me :)
Nic's averaging one a month at the moment, see my sig *wink*
Edited by Bat on 14th Jun, 2007.
curses!
steve1275
Member #: 951
Bromsgrove
Just fitted one of these as an engine inlet temp. gauge.Shows 10C rise over ambient on the run (big intercooler) but the heatsoak after shutdown is 35C over ambient.I've put the sensor on the plenum inlet,tucked between the Samco and the alloy pipe.
'Where does the engine go?'
MrTurbo
Member #: 814
Utrecht, The Netherlands
Hi Steve,
Do you have a picture of how you've installed the sensor?
steve1275
Member #: 951
Bromsgrove
Sorry,I don't,but I will try to take one tonight.
MrTurbo
Member #: 814
Ok, thanks! I found this one on a dutch site (watercooling doesn't ship to the netherlands). The sensor is for measuring water temperature. Would it work for measuring air temp as well?
steve1275
Member #: 951
Bromsgrove
Probably,but you would need to drill/tap the plenum inlet to fit it into the air stream.Mine is a simple stick on resistor wire sensor,so I could feed it between the plenum inlet pipe and the Samco silicone hose.It relies on heat transfer through the alloy,so probably reacts slowly.
eaton_mini
Member #: 1649
West Sussex - dreaming of forced induction!
Rather than buying leads why dont you just fit a 5V regulator?!?!?!
steve1275
Member #: 951
Bromsgrove
Um,in my case the 5v leads were only £2 extra from the same source and I have enough trouble keeping the smoke in the wires as it is.
just buy this
http://cgi.ebay.co.uk/DM-6802B-Thermometer...%3A1%7C294%3A50
they you can do before/after intercooler or intake vs ambient etc
cheap and cheerful
littlejem59
Member #: 2544
Biddulph, Stoke on Trent
On 23rd Aug, 2006 Richie said:
On 23/08/2006 13:33:19 giallofly said:
I'm loving this, nice try Mr 3 posts!
JF.
Enough said :)
no offence good buddy if ure intentions were all good, but everyone looks out for EVERYONE on this forum, Tom is simply trying to stop some of the "greener" members being ripped off (not that your a rip off) the whole point of THIS for sale section is to get high quality trusted items, second hand or otherwise at a good cost. and alas your item seems a tad pricey. you can buy reliable temp sensor gauges and probes from maplin for a 3rd of the cost (and the back light wont fail) Tom is looking out for everyones interests here mate if you dont like constructive criticism then this forum/family s not for you......
once again not having a go take it on the chin and chalk it down to experience bro. try selling em on ebay at ure price *wink*
Richie
nicely put Richie. *Clapping* *Clapping* *Clapping* although i dont post much on here i do follow it and your comments seem to me to illustrate the genuine spirit and intentions of the Forum.
edit:- whoops, didn't notice the dates, too absorbed in the chat. Yea allright bit of a clot
Edited by littlejem59 on 12th Jun, 2009.
It's not the age that makes me creak it's the mileage
