Home > Help Needed / General Tech Chat > Standard Gear box running 10 to 15psi engine
Markie_D
Member #: 1660
Formally Mini_Uk
London
What's a cross pin ? any links. and easy enough to fit.. i do have standard gearbox, will be running at 8 psi.
But i wont be going nut's in the car all the time..
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
Any one ? as ill be running around 10 psi, just wanna make sure ill be ok :)
Shit Happen's
Cross pin or 4 pin as it's also known, would be the diff.
Fitting is the same as a standard diff.
On 16th of Apr, 2007 at 05:19pm Mini_Uk said:
Should i think about getting one my self then ,even if im gonna run at about 8 (psi) is this the sort of thing to get ?
http://www.minisport.com/classic-mini-shop...pe-product.html
Are they easy to fit ?
People have had issues with the Minisport one breaking, while they may have changed the design it seems no one wants to be first to find out lol.
as mentioned Minispares sell th good ones aparently along with Minits, also I would expect the Avonbar one to be top notch too.
Zeemax Power
Member #: 393
Oulton Park
i brought a trans x one from avonbar but not sure how the shims work all back in and it seems to turn any ideas if thats right
http://www.Zeemax.com
Markie_D
Member #: 1660
Formally Mini_Uk
London
Would it be ok to run on 7 psi for the time being ?
Shit Happen's
t3gav
Member #: 229
Gavin@minispares.com
kent
Yeah 7psi should be fine for a good few 1000 miles
