| Home > Help Needed / General Tech Chat > Fitting Quaife LSD problems | |||||||
10th Jun, 2007 at 11:20:39pm
Cheers lads, and please pass my thanks onto your contact TD, im pretty sure weve homed in on the problem now
11th Jun, 2007 at 07:37:27am
yes to your second paragraph.
11th Jun, 2007 at 07:54:32am
i would agree with fastcarl, i had a JK crown wheel which has a small lip on the inside. when fitting the diff it would not sit flush with the crown wheel. i had the crown wheel machine to remove the lip which fitted flush. The bolts should be flush with the diff and not sticking out. |
11th Jun, 2007 at 09:00:50am
Right ill go down after work and check
11th Jun, 2007 at 09:06:27am
I would agree with Carl, my crown wheel was a JK, it had a lip inside which did not allow the diff to sit flush. i had the machine so it could sit flat on the crown wheel. The heads of the bolts should sit flush aswell. |
11th Jun, 2007 at 09:57:58pm
bingo, yes phil its sitting on that lip! so feels good in your hands, like its hitting home, but when looking through the bolt hole its way off.
23rd Jun, 2007 at 11:33:30pm
Righto, had the step machined back to allow the quaife to fully seat in the CW
24th Jun, 2007 at 12:29:45am
On 23rd of Jun, 2007 at 11:33pm joeybaby83 said:
and yes it would apear that all the grinding to the box i did was unnecessary after all. but think of the weight saving...... |
24th Jun, 2007 at 10:46:48am
Torqing up the diff bolts was fun, had to turn down the end of an old 9/16" sockey so it would fit inside the ring gear. Lol, i had to do that to. Have a special little socket for this purpose now. Glad you got it sorted. Phil. |
9th Jul, 2008 at 07:10:26pm
On 9th Jun, 2007 joeybaby83 said:
Righto, first problem was getting the pinion nut undone, but a volvo, some nosey neighbours, and a bit of scaffold bar it was soon sorted... I tried this technique on the weekend to remove a FD but couldn't jack up the Volvo any where near high enough, couldn't believe the amount of sag in the suspension. Off to think of a new technique. Isambard Kingdom Brunel said:
9th Jul, 2008 at 10:02:33pm
jack it up on the bottom wishbone |
9th Jul, 2008 at 11:30:40pm
10th Jul, 2008 at 12:34:44pm
why? "Turbo's make torque, and torque makes fun"
82 Posts Member #: 42 Advanced Member Doncaster |
10th Jul, 2008 at 12:48:11pm
Because in the UK we don't use U as it can be mistaken for a V.
10th Jul, 2008 at 06:14:17pm
On 10th Jul, 2008 GTM Turbo said:
Because in the UK we don't use U as it can be mistaken for a V. Must be different for the Isle of Man? We do now! Or since 2001 we have! On 5th Sep, 2011 Vegard said:
