| Home > General Chat > coolingmist / aquamist water injection????????? | |||||||
3596 Posts Member #: 655 Post Whore Northern Ireland |
16th Jun, 2007 at 12:47:27am
On 15th of Jun, 2007 at 11:10pm TurboDave said:
Whenever i've had 'heat soak', by the time I've done my burnout, the temps are back to civility once again - do you not find this the case with your setup Steve? If i had done absolutely everything else possible, then maybe I'd consider using mapped water injection... However; in this particular case where a roots blower is being asked to make high boost (something it doesn't do at all efficiently), a re-think on the supercharger type, or at the very least intercooling is by far the best option before waterinjection. I think this is what BenRoss was trying to get across), and hence the 'band-aid' designation is quite apt (IMO). I think highest intake temp ive seen, ( temp probe about 6" in front of the TB, mounted in stainless pipework ) is around 70degC. This was at the end of a pass. During a hard blast, my intake temps do generally rise, perhaps some 10degC or so, depending on conditions. During normal road driving, they rarely go much above 30degC though. When racing its a different matter. Just not enough airflow to keep things in check. Water/methanol injection is hard to beat at this point. Although Im using nearly 100% methanol. But very true, if you are using this method, to try and reduce temps etc due to using a very innefficient compressor, well beyond where it wants to be used, then it is not the correct way to do things. If using it as a further tuning tool, the is is very good IMO. Always opt for an efficient compressor, good intercooling, then if you want to push further, WI or Meth is an option. 9.85 @ 145mph
44 Posts Member #: 1645 Member Adelaide Australia. |
16th Jun, 2007 at 03:14:05pm
Lots of people use it here is Aus (water/methanol, usally in 50/50 amounts, from what I've read) on older supercharger designs, eg. Carby, then charger, then motor. Which is what I run. There are much more effiecients ways of doing things these days, but people like me work with this older ideas as it's the only way they can afford to get into boosted motors.
17th Jun, 2007 at 10:00:43am
![]() 6753 Posts Member #: 828 Post Whore uranus |
17th Jun, 2007 at 11:01:00am
looks like pros are ,
