| Home > Technical Chat > VNT15 use experience ? | |||||||
23rd May, 2008 at 08:57:15pm
retranslated i meant , how about trying some helically wound stanless steel wire ht leads to create better noise supression , a company called msd make the ones i use . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
13 Posts Member #: 1223 Member |
23rd May, 2008 at 09:36:00pm
I have modified the standart actuators and changed the spring today the actuator work well at 0.2 bar beetween 1500 and 4000 rpm and 0.5 beetween 4000 and 6000 rpm.
520 Posts Member #: 2093 Post Whore Grenoble, France |
24th May, 2008 at 12:22:24pm
valant1, I did the same. But I don't have intercooler, so I would not go up to 500mbar. And limiting at 0.3 at 6000 means nothing at 2000.
std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
24th May, 2008 at 12:24:29pm
On 23rd May, 2008 robert said:
retranslated i meant , how about trying some helically wound stanless steel wire ht leads to create better noise supression , a company called msd make the ones i use . Too expensive for me. I leave in 2 months, I would not invest much before leaving the car for 2-3 years. Anyway I'm not sure it would help. I'll try several things this week-end. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
25th May, 2008 at 03:54:00pm
alpa , i use a spy seal from industrie for the axle and a high quality glue to seal the inferior part. |
25th May, 2008 at 04:24:16pm
25th May, 2008 at 04:46:30pm
On 25th May, 2008 mini13 said:
I used a valve stem seal form a fiat 126 biz Would not it disturb with a light spring ? The pb with low boost is the spring becomes really light. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
25th May, 2008 at 04:50:37pm
quite possibly, I have not tried it yet.
25th May, 2008 at 04:55:30pm
I managed to filter/rewire everything in order to avoid the ignition side and make the servo work. Now the control is very good and rather precise.
25th May, 2008 at 05:46:01pm
25th May, 2008 at 09:41:25pm
On 25th May, 2008 Bat said:
Hi, Hitec are more commonly called lowtec in Rc circles
A multiplex Rhino or a alloy servo off the Chinese manufacturer on Ebay Cheers, Gavin :) Funny, US guys seem to appreciate Hitec. Chinese are reported to have a huge play around the target position, even digital ones. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
25th May, 2008 at 09:45:35pm
Ok, so it works and rather good.
26th May, 2008 at 04:33:12pm
26th May, 2008 at 04:51:25pm
really well done for perseverance alpa . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
26th May, 2008 at 06:08:07pm
On 26th May, 2008 robert said:
really well done for perseverance alpa . Thanks That's the fun trying new things. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
