Home > Show Us Yours! > The Damage [ piccies] the remedy upodate
On 18th Jul, 2008 turbo hogster said:
the lay shaft is different from a to a+ which means you would need to use a a+ laygear which in turb you would need to run a a+ gear kit.
why cant you use a a+ gear kit carl.
My pre A+ is in a A+ case, I had no issues with layshaft
Paul
Ditto (done it twice now).
The layshaft and lay gears are certainly different in terms of their needle roller numbers and sizes (so I don't think you can mix an "A" laygear set with an "A+" layshaft) but using "A" as a pair (shaft and gears) I found no difference in the sizes where they fit in the "A+" casing.
Rod.
i knew the lay shft and gear are different, and you cannot mix the two kinds , but as a apir ,i thought they could go, and as paul says ,
well i dloody well hope do as ive just modified an A + for the job,lol.
carl
opps double p[ost,lol
Edited by fastcarl on 18th Jul, 2008.
Well I've done it twice using a pair of "A" layshaft and laygears in an "A+" box (along with all the other "A" gears obviously).
As far as I can see, it's just a case of making sure it's a pair..... Then they fit fine.
EDIT - in fact one of the "A+" casings I got from a 1275GT from around the changeover time actually had "A" gears (GT set) with "A+" drops (larger diameter shaft to fit the "A+" casing) and "A+" CWP.
Note, that might be an issue for you, the "A+" casing has to have the larger diameter shaft on the drop gear.
Edited by Rod S on 18th Jul, 2008.
I ran mine for 9 years, only just removed it from the car to upgrade. I gave it no end of grief so there is deffo no problem with A gears in a A+ case
Paul
thanks fella's, mind at rest now.
carl
Just don't forget the drop gear bearing size is different, the "A+" casing won't take an "A" drop gear (as per my edited earlier post).
Rod.
EDIT and the "A+" reverse idler has to remain, the "A" one has the groove for the selector arm/fork in a different place to the "A+" selector mechanism.
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
I also used A gearkits in A+ box, but didn't find it to be a fall in job, I needed to mold the box casing to give some clearance to the A shaft to drop in.
i'd heard this from the guy who does my gearboxes, where does it need releiving, i'd rather do it than have him hack it out,
carl
Ah yes, Id forgotten about that, the centre web needs relieving a little above the mainshaft bearing, just enough for the mainshaft assy to drop in.
Paul
Paul
you meen the bearing next to the pinnion,
if so it will need releiving on the opp side to pinnion,
[iv'e never put a box back together yet]
Yep you've got it. If you go to fit youre mainshaft you will see exactly whats needed
Paul
Edited by Tom Fenton on 23rd Jul, 2008.
nice one carl!
if a jobs worth doing its worth doing properly!
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Holy f&%^$kin sh%^t !!!
"Try to take over the world!"
Those links dont work for me
Paul
Looks like you're cracking up Carl!
devcon?
On 23rd Jul, 2008 robert said:
devcon?
nope Robert , sorry mate you have to speek English
It is like that epoxy steel stuff, but more expensive.
I think Robert was practising the English art of sarcasm.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Quick a double post! Someone get Tom Fen... oh.
Edit- Aw that's not fair, mods can delete their double posts.
Edited by Jay#2 on 23rd Jul, 2008.
On 7th Nov, 2008 Nic said:
naeJ
m
eh?
Jay#2
Member #: 648
Must be me, you post came up twice on my screen.
naeJ
m
