Home > Help Needed / General Tech Chat > Con Rod Order
hario
Member #: 2885
surely 'offset-little end' is the right phrase to use here..
*happy*
no because its the big end *tongue*
hario
Member #: 2885
damnit.
was rading vizard the night before and remembered something about machining the little end central, must have been for fitting a diff. crank..
Je suis desloé
*tongue*
Désolé?
That's when fitting S rods in a small bore engine.
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Sprocket, im sure no-one gives a shit on the exact wording, "offset" and "handed" give the same sort of impression to me, as im sure they do for other people.
Perhaps answering the guys question is all that needs to be done instead of being a tad petty.
Chris:
That pic shows how the rods go on your crank, you can see the different shapes to them, with the offset sides pointing INWARDS on rods 1 and 4, and OUTWARDS on 2 and 3.
If you plonk the crank into position and look down the bores, you will be able to see that the crank journals are offset to the bores, it will be clear to see which rods need to go where.
The question was answered a long time ago, before the sarcasam started, but it seems you have taken it that i am being a funny bastard about it, not so, hence the use of the smileis *wink*
Ben.
Member #: 1064
Formally Whyte_ben
Horndean, Hampshire
Build Thread Click Here
Mr Mini
Member #: 346
Portsmouth
Richminiturbo.
Many thanks for that.
Chris.
1310cc TWINK - T Conversion
being petty would be pointing out that 2 & 3 are missing their oil control rings haha
