| Home > Help Needed / General Tech Chat > Dry decking - which waterway holes do you block up?? | |||||||
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
13th Mar, 2011 at 02:51:29pm
On 12th Jun, 2010 apbellamy said:
You can't achieve true perfection with out knowing how it feels to completely fuck it up. i like that! one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
306 Posts Member #: 7107 Senior Member essex |
13th Mar, 2011 at 03:05:55pm
does any one have pics of the work thats needed |
432 Posts Member #: 7856 Senior Member Essex |
13th Mar, 2011 at 08:30:24pm
I too am making them myself, as I already tapped it the wrong thread :( Annoying, hence my post, to stop someone else making this mistake as not everyone has a lathe!
Edited by Amp on 13th Mar, 2011. |
13th Mar, 2011 at 08:43:07pm
thanks that helps loads where did you buy your water ways from i was gona get mine from mra |
13th Mar, 2011 at 08:45:35pm
Fastcarl does them, as does Turbophil, or, see pm :) |
13th Mar, 2011 at 08:48:40pm
turbo Phill does them for 50 quid,
13th Mar, 2011 at 08:48:49pm
pm.ed |
![]() 130 Posts Member #: 9395 Advanced Member |
15th Mar, 2011 at 12:23:02am
When the dry deck kit is fitted to the side of the block and head, does the engine steady bar and brackets still fit, or do they need to be modified or moved? |
15th Mar, 2011 at 09:42:31am
On 15th Mar, 2011 ntm1275 said:
When the dry deck kit is fitted to the side of the block and head, does the engine steady bar and brackets still fit, or do they need to be modified or moved? the little bent bracket on the engine side of the steady needs a bit of a trim and i trimmed a bit of one of my water ports aswell Yes i moved to the darkside |
