| Home > Help Needed / General Tech Chat > Cast or forged? | ||||||
10th Mar, 2005 at 07:42:00pm
I found the pictures for the zetec oil sqiurters on mini williams site.any one know the part number to save a lot of explaining up the ford garage!!,and which way is best to mount siamesed or singular ??
10th Mar, 2005 at 08:26:25pm
10th Mar, 2005 at 08:27:48pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=1055
10th Mar, 2005 at 08:40:34pm
Incidentally, Those links were found by using the following feature on the TM forum board On 17th Nov, 2014 Tom Fenton said:
35 Posts Member #: 397 Member |
11th Mar, 2005 at 07:07:45am
http://www.minispares.com/Product.aspx?pid=35484
11th Mar, 2005 at 01:18:54pm
here is the installtion of the jest in my engine, thanks again for dave for the engine build, food, beer, and looking at lots of women.
11th Mar, 2005 at 01:31:07pm
I machined the dish to 11cc. These sit a little further down the bore than the original 'turbo' piston, hence you don't machine it any further.
11th Mar, 2005 at 08:17:46pm
how about ceramic coating the tops of the cast pistons? any opinions on that? |
11th Mar, 2005 at 09:06:44pm
Not for me thanks - I'm not building a WRC car. On 17th Nov, 2014 Tom Fenton said:
![]() 2641 Posts Member #: 19 Post Whore newcastle |
11th Mar, 2005 at 09:36:37pm
only looiking to go up the strip in 13.7 sec , not re enter the earths atomsphere Everyone knows that instructions only have to be read if the thing doesn't work....
11th Mar, 2005 at 10:11:33pm
On 11/03/2005 20:17:46 greypride said:
how about ceramic coating the tops of the cast pistons? any opinions on that? If only I was still on night's would have a set by now.Think you have to buy the next size up and machine them due to distortion during heat treatment
12th Mar, 2005 at 07:33:59am
Ceramic coating is pretty thin and is usually applied to the crown only. There is another coating that is applied to the skirt to minimize friction but that is another issue. It does not affect the piston size or shape.
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
12th Mar, 2005 at 05:01:12pm
I'd go for the cast. The minispares items are basically the metro AE item.
14th Mar, 2005 at 01:53:16pm
If you look at it that way it 'MIGHT' be ok for pistons 3&4, but 2 might not get a lot of spray, and i'm sure the speedo drive won't help #1 piston too much! On 17th Nov, 2014 Tom Fenton said:
195 Posts Member #: 26 Advanced Member Cannock |
16th Mar, 2005 at 12:44:08pm
Seems like a fair point with regards to pistions however there are other areas in which ceramic coating could help 99% of turbo minis. I for one will be having the pistons and the exhaust coated. The 2nd mainly to keep the heat in the exhaust and away from the rest of the engine bay.
Edited by BA_Lordflash on 16th Mar, 2005. |
