Home > Help Needed / General Tech Chat > New engine smoking badly!
jimmy
Member #: 829
essex
when you run the engine did it getting hot ?or just normal
1293 Turbo mini
adamt
Member #: 9181
Rhoose, Cardiff
when it was sat idling for a while it did get a bit hotter than normal
My project Toyota powered mini: http://www.turbominis.co.uk/forums/index.p...tid=470448&fr=0
jimmy
Member #: 829
essex
like it as been said you need to get so miles on it first be for you start taking it part just one thing i would say is was the rings gaped ? because when it got hot is when you can brake a ring
Edited by jimmy on 6th May, 2011.
1293 Turbo mini
guides?
keep us posted please!
adamt
Member #: 9181
Rhoose, Cardiff
i imagine the rings were gaped when it was built. Like you said a good long run might sort it
adamt
Member #: 9181
Rhoose, Cardiff
yeah i will keep you posted. im away from home atm but should be back to work on it wednesday
tadge44
Member #: 2500
Buckinghamshire
Tom puts it so well _ I have already offered him my apology when he told me the same thing and with a few miles on it and bit of discreet thrashing its fine.
hydrolastic
Member #: 6668
Hello We run the race engines (NA) on the Dyno (rolling road) to break them in. Here is how. Have the dyno operator set it up with low resistance. Do three runs up to 3500 then three runs up to 5500 then three runs up to 7500. The last engine i had to do another set up to 7500 but the rings were thicker on the swifty pistons. they smoke pretty good then the room magically clears up. Once it's broken in, start the power runs.
Racecar spelled backwards is Racecar
adamt
Member #: 9181
Rhoose, Cardiff
That sounds good, im gonna have it set up properly soon anyway so it makes sense. Thats if it hasn't already been broken in before then though
I must have missed this?!!!
tadge44
Member #: 2500
Buckinghamshire
OK Tom here it is
You said stop fretting and get some miles on it - later in the same thread I acknowledged how right you were and offered an apology for doubting you.
I have an inbred lack of self confidence with engines !!
Splendid, is this where if I was a gloating bugger I could say I told you so? *tongue*
Could the fact some engines smoke and others don't be due to way the bores have been honed?
the bores on my engine looked quite rough compared to the mirror finish you see in the likes of med photos when honed also my mates, however they didn't smoke at all at first start up. these were using std turbo pistons and 73.5 powermax ones respectively.
