| Home > Wanted > Metro Turbo boost solenoid | |||||||
3rd Aug, 2011 at 12:48:44pm
Ahh, that gets a bit more complex. |
3rd Aug, 2011 at 01:25:19pm
Button on the wheel . piece of cake On 11th Feb, 2015 robert said:
3rd Aug, 2011 at 05:18:12pm
On the hillclimber I have a switch on the gearstick that detects first (and maybe second) gear. This activates a solenoid that drops the boost.
http://www.twin-turbo.co.uk
3rd Aug, 2011 at 05:29:22pm
I was thinking even cruder than that Ben...
Typically, I can't read. That arrived today and it's just the fooking hose. BAC ebayer with his confusing pictures. The hunt continues. Arse. Edited by apbellamy on 3rd Aug, 2011. On 11th Feb, 2015 robert said:
3rd Aug, 2011 at 05:48:09pm
I thought the solenoid was just an on/off thing on the metty Yes i moved to the darkside |
3rd Aug, 2011 at 06:05:37pm
On 3rd Aug, 2011 Brett said:
I thought the solenoid was just an on/off thing on the metty I would have expected so - but I must stress I don't know, never seen one, but from its age, probably. If it was a modern PWM modulating valve you would need to know the PWM frequency to enter into MS anyway to get it to work best. For the MS boost control, an Amal valve from a Cossie is probably the cheapest UK option, you can get them on eBay for less than £8 if you bide your time :) Schrödinger's cat - so which one am I ??? |
3rd Aug, 2011 at 06:20:15pm
I think the solenoid valve on the Metro was PWM, remember the ECU had a MAP sensor on board, and also a revs input from the coil.
3rd Aug, 2011 at 06:26:10pm
Fair point Tom, like I say I've never seen one, just surprised for that age.
3rd Aug, 2011 at 06:32:17pm
anyone got a free metro ecu Yes i moved to the darkside |
3rd Aug, 2011 at 07:01:51pm
I use a Saab valve (because I have one) but they seem a bit expensive on ebay
3rd Aug, 2011 at 07:18:41pm
My weapon of choice....
3rd Aug, 2011 at 09:48:21pm
the metro one can be uses as an on/off because ive used it as that on my last build
3rd Aug, 2011 at 09:56:11pm
bought a cheepo one of a vauxhall as MITP is getting closer and the van has now been banished from my garage, so spanner time will be limited to the morning before we set off... On 11th Feb, 2015 robert said:
![]() 489 Posts Member #: 9159 Senior Member Devon |
4th Aug, 2011 at 08:48:01pm
i like the idea of this one!
4th Aug, 2011 at 08:57:46pm
Yes
17th Sep, 2011 at 08:25:40pm
thats great thanks! what type of switch are you going for? a simple on/off switch?
18th Sep, 2011 at 01:20:47pm
yes, just a little flick switch taped to the steering wheel On 11th Feb, 2015 robert said:
18th Sep, 2011 at 04:30:58pm
they would be good but you would have to hold the button in, not ideal.
On 17th Sep, 2011 jamestar said:
thats great thanks! what type of switch are you going for? a simple on/off switch? i've been looking at these but they're momentary contact switches: http://www.demon-tweeks.co.uk/Motorsport/S...ttons/1766/1121 Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
18th Sep, 2011 at 07:15:36pm
this is true! tbh might just make my own, bit of ally sheet, a switch and some cable.. job done |
18th Sep, 2011 at 07:38:20pm
yeah be easy enough, i plan to do the same a after car is on the road. Audi s4 b5 - 470bhp & 486ft lbs
18th Sep, 2011 at 08:10:25pm
i plan to mount a switch into one of the holes in my wheel...
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
18th Sep, 2011 at 08:13:14pm
you could always just get an Apexi AVCR...... On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
18th Sep, 2011 at 08:16:30pm
ill stick with the £10 set-up Audi s4 b5 - 470bhp & 486ft lbs
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
27th Sep, 2011 at 12:40:11pm
I have two Metty turbo boost solenoid valves with the wires and connectors intact.
Edited by turbominivanman on 27th Sep, 2011. Minivanless, but reluctantly happy living with the decision. There'll be another one day.
![]() 562 Posts Member #: 9285 Post Whore Oxfordshire |
26th Aug, 2012 at 07:53:31pm
A bit of a thread revival but would the following be suitable?
