Home > Help Needed / General Tech Chat > boost spiking
@ wil_h... I'd say you need more preload on your actuator to, or there's something wrong with the bleed valve. Try it with the pipe off the actuator and see what you get, be careful not to go silly though! If you still only get 18psi you need more preload.
Gavin.:)
