Home > Show Us Yours! > my tahiti blue turbo
love the car it looks super, really nice.
I see you have fitted a magnet in the oil feed to the pump, you'll find that that does NOTHING at all, i've had one like that one mine and have taken it off, as there is never any thing on there to worry about. *wink*
jimmy
Member #: 829
essex
i fiited a magnet in the pick up on the gaerbox
1293 Turbo mini
steveobennet
Member #: 1657
wirral
cheers all, yep, its a bugger to get out and clean when doing an oil change aswell! its picked up abit of swarf but only very tiny ammounts that have managed to get past the gauze.
On 15th of Apr, 2007 at 09:08pm Vegard said:
What the fuck is that on the rear of the car? One of the most stupid things I've ever seen. Rest looks nice.
10.5 psi no idea how many banannas
mlarj
Member #: 2397
Plymouth
Hi, car looks really nice but I have a question regarding the suspension set-up. I am thinking of ordering the RSX520 kit from minispares.
Do you have any clearance problems at the rear using 13 inch superlites? thinking more the inside top and the spring?
steveobennet
Member #: 1657
wirral
clerance of the coilovers to the wheels is fine, so long as you use the drums with the 1" spacers. you might have to modifiy the inner arch itself to accomodate the larger shock/spring. also if you are thinking about going really low on the rear then i suggest you "tub" the rear arches (remove the curving down bit of the outer arch).
mlarj
Member #: 2397
Plymouth
Thanks for the info. My plan is to replace the very old spax adjustables, the original ripspeed hi-lo's! and ageing cone spring rubber.
Would you ever look 'back'? or are you convienced your current setup is the betterbest solution?
steveobennet
Member #: 1657
wirral
no much has been done lately. so i thought i would replace my rusty a-panel and fit a new intercooler.
this was the state my a-panel was in, so thought its only best to renew the panel.
the rust behind it. all removed and the metal that was left was treated.
new panel on, lined up. its a non-genuine panel so it took abit of fiddling but its on now.
some rust proof hammerite primer. lets hope it does its job.
and final colour on.
also decided to get a new intercooler that could fit directly behind the grille. this one was from an audi a3 or a4. fits a treat plus its right in the airflow so should keep the air cool!
also fitted my oil cooler. because its summer my oil has been seeing close to 100oC on the warmer days (not that we'll get anymore!).
New IC looks just the job :)
