Home > General Chat > Turbo oil feed hose
confusednewowner
Member #: 854
Fareham, Hampshire
I just purchased one of these from ebay but I was wanting to confirm the sizes for the fittings on each end, the seller says he has sold 50+ of these for turbo minis and the fittings are 10mm in size.
Would this fit the T2 turbo and the block? Or are they different sizes?
Thanks
It won't fit the T2 turbo.
The hoses generally available for sale are for minis fitted with the standard metro T3 turbos.
You should have bought one off Iain here as he can supply a T2 specific hose.
If you had read the replies to your previous post on this subject you would know that too......
confusednewowner
Member #: 854
Fareham, Hampshire
Yes I am a fool, will definately have to not get carried away with ebay again and use the search button on here to better effect!
Thanks for the reply anyway
You can buy the ends to convert the T3 hose to a T2. This thread should have all the info you need.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=8057
I bought the ends I needed from here http://www.thinkauto.com/
But they did need some machining.
Wil
