| Home > Help Needed / General Tech Chat > Fuelling problems on new set up | |||||||
![]() 608 Posts Member #: 1106 Post Whore Hungerford, Berks |
14th Jul, 2006 at 08:33:42am
We have just recently finished putting a Metro turbo unit in a 1985 Mayfair shell.
’77 Clubman build thread
14th Jul, 2006 at 08:36:42am
sure the timing is right? any better or worse with the choke out? |
14th Jul, 2006 at 09:04:38am
Done the Tee piece trick in daves guide?? (putting a t piece in place connecting the fuel pressure regulator, the plenum outlet and the anti run on valve outlet all together) Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
14th Jul, 2006 at 09:06:04am
that wont make any difference off boost |
14th Jul, 2006 at 09:33:42am
We timing is set up correctly. Using the choke makes matters worse.
14th Jul, 2006 at 09:40:25am
Firstly, lift off the dash pot and then turn on the fuel pump. you should see no fuel coming up the jet, if you do it's likely that there is a problem with the float bowl needle jet.
16th Jul, 2006 at 08:36:06am
Thanks for the help wil_h. That was exactly the problem. Float level was set incorrectly. Reset float level, re checked fuel pressure, turn the key and the result was a very satisfing purr after 3 years of rebuild.
16th Jul, 2006 at 10:10:05am
well hello and welcome...
AlexF |
