| Home > Help Needed / General Tech Chat > Clutch | |||||||
6th Aug, 2006 at 10:24:04pm
F-ing clutch has let me down again
6th Aug, 2006 at 11:42:03pm
Did you have the clutch properly adjusted - ie the arm isn't hard up against the 1/4" (7/16 spanner) adjusting bolt on the flywheel cover?
Edited by turbodave16v on 6th Aug, 2006. On 17th Nov, 2014 Tom Fenton said:
7th Aug, 2006 at 01:49:13am
me and kean both machined our backplate lugs down to 23.5mm the week before Avon park as keans slipped at 15psi. After it was modded and the spring sat flat the clutch was a lot lighter and no slipping at 165lb/ft for me anyway. On 20th Oct, 2015 Tom Fenton said:
7th Aug, 2006 at 08:41:31am
it was adjusted correct Dave, i use 6 straps and nothing has been machined, i will strip it all out this weekend and start again Crystal Sound Audio said:
7th Aug, 2006 at 09:35:15pm
right going to whip the clutch out tomorrow night
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
7th Aug, 2006 at 09:40:48pm
iether a lathe or a milling machine "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
7th Aug, 2006 at 09:44:31pm
sorry to sound stupid but what do you gain from maching the lugs?
My build thread..
7th Aug, 2006 at 09:46:18pm
http://www.turbominis.co.uk/forums/index.php?p=search
7th Aug, 2006 at 09:54:28pm
enter 23.5mm in the search field, tick the 'thread body' box, and there are several posts about it.
7th Aug, 2006 at 09:56:39pm
I had to run my grey with the bolt wound into the arm - to get enough clutch movment to disengage :S
AlexF |
7th Aug, 2006 at 10:15:15pm
On 07/08/2006 21:56:39 AlexF2003 said:
I had to run my grey with the bolt wound into the arm - to get enough clutch movment to disengage :S I never did work out why! Alex I had the wierdest thing this year - maybe related - but that's not to say i fully understand the reasons.... I too have always had to wind the stop out, such that the 'free play' was taken up - and the arm 'resting' on the bolt, but not under any force. This year, i haven't needed to adjust this once - and the arm is currently sat around 3mm off the head of the bolt. EVERYTHING is as per last year - except that I bled the clutch as I'd slackened off the braided hose on the top of the master to re-orient it. Clutch hadn't been re-bled for a good few years previously, but i NEVER remember the clutch being like it is now. Very strange indeed!
7th Aug, 2006 at 10:22:53pm
i've always had grief with mine. I bought all new clutch components arm/slave/plunger/pins etc and still couldn't get enough travel on it. ended up jamming 2 nuts inside the slave to get the throw i needed. On 20th Oct, 2015 Tom Fenton said:
7th Aug, 2006 at 10:28:44pm
7th Aug, 2006 at 10:31:05pm
On 07/08/2006 21:35:15 wolfie said:
whats the best way of machining the lugs? stick it in a lathe ?? I can do them at the weekend on the surface grinder
12th Aug, 2006 at 09:55:52pm
its all stripped out
13th Aug, 2006 at 05:20:43am
plate should be ok.
13th Aug, 2006 at 01:14:04pm
I made up an adjustable pin as mine had worn down, one of those things you end up having to do to get to work the next day.
13th Aug, 2006 at 09:41:26pm
The AP organic road/rally plate (the best) is dark charcoal grey - the 'road' one is a shiny biscuit brown.
13th Aug, 2006 at 09:53:14pm
Best not to have the throw out stop wound out so far as to have the release bearing spinning all the time, this will lead to failure of the bearing in double quick time!
