Home > Help Needed / General Tech Chat > Dodgey Engine stand!
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Hi guys, went and made purchase of an engine stand from machine mart today, got it all out of the box and assembled it, piece of cake. The only thing i am concerned about is the way to mount the plate on the block to slide in the stand, the only way i can think of that is partially sturdy is mounting it on the back like this:
But think its still a bit sketchey, only 2 bolts holding quite a bit of weight. Should i try and find a way to use the arms on either end? If i did it would over hand and have more shearing force on the bolts i reckon but im not sure how to do this. I did a seach and theres talk of making brackets to mount them onto the stand. Ive got the Bill Sollis dvd of him building a 1380 and he mounts the bracket like i have! What would you lot do?
Cheers, Rich
Edited by richminiturbo. on 21st Aug, 2006.
i have one of those,
I mounted it on the front on the alternator mounts and also on the oilfilter mouting holes witha spacer, i'll see if i can do some pics later.
oh i think i had to drill an extra hole in the stand too.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=7967
Edited by joeybaby83 on 21st Aug, 2006.
Thats how i use the stand, but, the plate is at a slight angle so it sits above the flange and is parallel to the block. Looking at it from the back with the mount pointing towards you, it needs to be turned a little counte clockwise.
Oh and use thicker washers too, or there might be trouble. High tensile cap hed bolts are a good idea too.
If you can wait a few weeks and are feeling flush I going to make up a batch to sell on the bay.
neil_g
Member #: 1175
Nr Bournemouth
i use the fuel pump bolts as per the original pic, hasnt fallen off the stand in the 2 months its been on there..
i actually drilled 2 specific holes in the plate, stops the block sliding around in that groove.
richminiturbo.
Member #: 719
Hmmm i dont know wether to go for it like i have now and see what happens or wait and get one of these speacial plates. Prob just end up drilling come new holes like you said...*oh well*
Guessworks
Member #: 651
Rugby, UK
You want one of these.... try contacting spitfirebob on theminiforum...
paul25
Member #: 596
Must admit, mounting my engine using 2 bolts made me nervous but the it remained intact for over 6 weeks. As mentioned earlier make sure you are using high tensile bolts (10.9) and a couple of thick washers and you'll be OK
