Home > Help Needed / General Tech Chat > number of teeth on 1st gear?
Hi, just a quickie,
How many teeth should there be on both of the 1st gears (if that makes sense).
Trying to work out if mine is Clubman set or long 1st gear!
Cheers *happy*
turbo hogster
Member #: 178
stowmaket suffolk
clubman set use a standard first gear but with a extra tooth on the layshaft hope that helps
turbo hogster
Member #: 178
stowmaket suffolk
sorry laygear
Ive got a SC gear set but im not sure which type it is?
Do you know how many teeth are on the standard first gear?
Im not 100% sure if im counting the right ones, but one gear had 25 and the layshaft had 19, does that sound like the right gears? they were the nearest to the idle gear or clutch end?
Dangerous
Member #: 417
25 dont count that is part of the input pair
some numbers here
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=3717
a nice one I tried all sorts of things in the search section. Never thought to put 'cog' into the search. lol
I'll do some counting tomorrow and see what it ends up at.
this was your ratios Dangerous. Is this the standard SCCR box ratios or Clubman?
1st 31/14
2nd 27/18
3rd 24/21
4th 22/23
Dangerous
Member #: 417
Can't remember now
If you look on here they have a handy gear ratio calc you can download it has the mini ratios allready in it
http://www.manchesterminis.co.uk/
Right counted the teeth...
Layshaft 15 19 23 25
main shaft 29 25 22 19
Ratios 1st 2.53
2nd 1.7
3rd 1.24
4th 1.1
diff 59/19 I work the diff out to be 3.1:1?
Ive also looked at the crosspin diff. The spacing between the planets gears is unequal,i asume that means it is a minispares diff?
Edited by matty on 5th Sep, 2006.
Matty,
The drive in 4th is 1:1 straight through.
Edited by Paul S on 5th Sep, 2006.
Guessworks
Member #: 651
Rugby, UK
"Ive also looked at the crosspin diff. The spacing between the planets gears is unequal,i asume that means it is a minispares diff?
All xpins have the planets slightly off square, if the cross pins are held in by a single allen bolt then it's a Tran-x or Minispares (MS is a copy of the Tran-X) if held in by push pins then it more likely to be minispeed or minisport
Edited by Guessworks on 7th Sep, 2006.
I had a look to see where the planets were held in but couldn't see anything, Im guessing they must be located under the crownwheel?
Is there any other identification marks on the m.spares diff?
Edited by matty on 7th Sep, 2006.
Wrong. The minisport diff is at 90 degrees.
At least I can rule that one out...thank god. :)
