| Home > Help Needed / General Tech Chat > T2 sell or not? | |||||||
113 Posts Member #: 1230 Advanced Member |
5th Sep, 2006 at 04:15:28pm
There are 2 people that want to buy my R5 T2, i also have a T3 from a metro, should i shell the T2 or T3? Or keep them? what does turbo dizzy mean? And how can i lower my compression, can i only lower the compression by placing other pistons? thanks |
5th Sep, 2006 at 04:29:01pm
I would keep the T2.
5th Sep, 2006 at 08:40:17pm
i can perform this task for you
5th Sep, 2006 at 09:51:32pm
Benross's work is fantastic and to a very high standard Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
5th Sep, 2006 at 10:03:35pm
and if you go and pick it up you will be treated like a king!! |
5th Sep, 2006 at 10:55:48pm
i don't understand what ure saying?? i have bought a 1275 metro engine, and i have also bought a complete kit of a metro turbo so inlet and outlet turbo carb and T3, but 2 weeks ago i also bought a T2 so what to use? and now i have to lower the compression because i want to turbo my metro engine (thats fits in a 91' mini) |
6th Sep, 2006 at 12:41:32am
How mechanically conpetent are you? If you're handy with a welder, tap and die set, etc - then the T2 is a mod you may want to make.
6th Sep, 2006 at 01:25:35am
6th Sep, 2006 at 07:38:30am
thanks for all replies,. It's the first time i'm going to work on a mini, and the first time i'm going to work with turbos. What i want is a mini with a engine for road use, and i want it to go fast from 0-60,... And i love turbos so i want it to have one, i'm now searching for a NA metro engine, and i know i have to change a lot of things. Can i put a turbo on every 1275 NA engine? |
6th Sep, 2006 at 01:17:31pm
6th Sep, 2006 at 03:40:12pm
so if i would buy an mg metro NA engine , the compression would be to high to put a turbo on it, so i have to chance the pistons then? Wich engines doe have a low compression ratio? what about a 998? because theres a 998 in the mini now. thanks |
6th Sep, 2006 at 04:23:57pm
thanks for the reply, i don't know what the CR is on a 1275, but i'm going to check it. WHat would be best a 998 turbo or 1275 turbo? what about the torque and hp on a 998? |
6th Sep, 2006 at 07:20:59pm
also what is your budget? no longer a series, but still 1.3 turbo.
6th Sep, 2006 at 08:20:43pm
arround 2000 euro |
583 Posts Member #: 233 Post Whore Beugen, Netherlands |
6th Sep, 2006 at 09:11:36pm
I will send you a PM:cool:
![]() 455 Posts Member #: 953 Senior Member London |
6th Sep, 2006 at 09:49:49pm
. Edited by Bodge Job on 31st Mar, 2007. |
6th Sep, 2006 at 10:57:31pm
stuur maar door |
send it
