| Home > Help Needed / General Tech Chat > Whats causing my engine to smoke? | |||||||
7th Sep, 2006 at 08:06:36pm
Hi, im having problems with my mini smoking, it just started yesterday and its quite bad. I was just wondering what it could be.
7th Sep, 2006 at 08:52:17pm
Remove spark plugs and check for washers
7th Sep, 2006 at 09:08:55pm
:) Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
7th Sep, 2006 at 09:13:06pm
Have you run th engine in
7th Sep, 2006 at 09:31:25pm
yep engines been well run in
7th Sep, 2006 at 09:43:15pm
Nope - you can have badly mangled rings and stiull have a good reading - the excess oil there because of the dud rings makes sure of this.
7th Sep, 2006 at 10:24:51pm
is a leak down test where you pour something in the bore and watch it sink down?
7th Sep, 2006 at 10:29:06pm
Just been trying to work out how that could work in my head, and just thinking that its the oil sealing the rings and giving good compresion readings, but still letting oil in?
7th Sep, 2006 at 10:33:34pm
actually bugger it ill just take the head off might aswell i just didnt want to do it if there was tests i should do on the rings first :) Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
7th Sep, 2006 at 10:34:02pm
Is it ok to test compression by turning it over when oil is out?
Edited by Dangerous on 7th Sep, 2006.
8th Sep, 2006 at 08:03:51am
Yeah course i do, isnt that how everyone does it?
147 Posts Member #: 814 Advanced Member Utrecht, The Netherlands |
8th Sep, 2006 at 12:31:09pm
If you do have a problem with the valve stem seal there is an easy way to replace them without removing the head and without buying expensive tools (you do need an air compressor..).
8th Sep, 2006 at 01:27:30pm
Thats quite a cunning method? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
8th Sep, 2006 at 01:28:06pm
Its ok without a photo!! understand that fully!!
8th Sep, 2006 at 01:33:20pm
It could be your valve guide thats at fault, worth checking whilst checking the seals and saves stripping the engine! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
8th Sep, 2006 at 02:10:42pm
just take the head of. Esp on an na engine it will take less than an hour. |
8th Sep, 2006 at 03:10:13pm
Yeah rope in the spark plug hole just don't lose the end of it in there though! On 7th Nov, 2008 Nic said:
8th Sep, 2006 at 03:19:15pm
That's why i'm using the spark plug tool trick, you'll only lose some air... |
8th Sep, 2006 at 05:18:18pm
Still seems like more hassle than it's worth. I can whip a head off in no time and i'm a total novice. |
8th Sep, 2006 at 08:13:23pm
Edited by Bat on 8th Sep, 2006. VEMs Authorised Installer / Re-seller. K head kits now available!
8th Sep, 2006 at 10:04:59pm
it aint the stem seals feebs
8th Sep, 2006 at 10:06:06pm
Gudgeon pin has got out and scored the bores/fucked the rings is my guess.
8th Sep, 2006 at 10:18:56pm
yes tom
9th Sep, 2006 at 10:17:28am
Completely joining Dave Tom and Ben,
Edited by fab on 9th Sep, 2006. |
9th Sep, 2006 at 11:48:40am
On 07/09/2006 20:06:36 feebleuk said:
Hi, im having problems with my mini smoking, it just started yesterday and its quite bad. I was just wondering what it could be. very hot or burning oil makes the smoke
) by mounting a 3-5mm metal strip over the front head studs and use a spanner (under the strip and over the spring) to remove the spring holder cups.
thankyou
