Home > Help Needed / General Tech Chat > HILO kit spanner sizes ??
b12
Member #: 247
Kent/Surrey Borders
Hello all
does anyone happen to know what size spanners are need to make adjustments to a hilo kit ??
I think the adjustablr rod is 1 inch but I am not sure about the lock nut
Thanks
Steve
TurboLessTosser
measure the flats on the the nut and there you have it!
The lock nut should be the same size as the adjustable bar as far as I remember!
I guess different manufacturers would be different though.
Get your very-nears (vernier) out, easiest way.
Edited by matty on 19th Sep, 2006.
Turbo Tel
Member #: 588
Delaware, USA
Did you ever find out which sizes are needed, just iunstalled mine and forgot to think of checking that before AI started.., 1 inch seems about right for the adjuster but wahts the lock nut?
Terry
Anton
Member #: 764
Staffordshire
the proper rac jobbies from minispares are 28mm and 32mm
t3gav
Member #: 229
Gavin@minispares.com
kent
26mm and 32mm :p
Turbo Tel
Member #: 588
Delaware, USA
OK Thanks..
FYI I seem to be seeing around 1/4" lowering for each full turn of the nut. In the end I was surprised how much room there was to swing a spanner and an adjustable did the job.
Its soooo nice to hit bumps in the road and not get the scraping noise and burning rubber smell!! Plus I think the rates are better, seems to be a smoother ride.. or is that my imagination?
Yeah they're a different radius on the top which alters the spring rate, apparently...
