| Home > Help Needed / General Tech Chat > water problems- updated again lol | |||||||
![]() 341 Posts Member #: 259 Member grays, essex |
18th Sep, 2006 at 03:56:41pm
Im having a slight proplem with the water in my metro turbo.
Edited by 1976_mini on 4th Nov, 2006. it may b small but it purfectly formed
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
18th Sep, 2006 at 04:19:47pm
electric fan? |
18th Sep, 2006 at 04:33:43pm
yea, the metro turbo has an electric fan as standard!
18th Sep, 2006 at 04:44:17pm
Sounds like your cap is not holding pressure. Is the seal OK? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
18th Sep, 2006 at 05:14:33pm
These caps are prone to failing, chuck it and buy yourself a NEW one. If that doesn't cure it then it may be the head gasket....... :(
18th Sep, 2006 at 06:21:06pm
thanks people, had a suspision of the cap, now others have suggested it ill try that.........1st anyway, lol. it may b small but it purfectly formed
18th Sep, 2006 at 06:24:58pm
proble the easiest and cheapest thing to try first anyway!
My build thread..
26th Oct, 2006 at 02:30:59pm
ok, so changing the cap has stoped water bubbling out of my cap when i turn her off, but it never cured the overheating problem. Ive changed the headgasget, checked block and head surfaces for warping, and wired the fan in permenantly. But still shes overheating, ive tried flushing the system thru to see of theres an air lock but i cant see any bubbles at all.
26th Oct, 2006 at 03:11:42pm
Is the radiator full of shit? Are you SURE it is clear?
26th Oct, 2006 at 03:37:34pm
yep, im sure. ive even put some rad clear stuff in aswell. it may b small but it purfectly formed
26th Oct, 2006 at 03:53:01pm
Have you checked your ignition timing. A lot of retard can cause overheating.
26th Oct, 2006 at 06:55:29pm
27th Oct, 2006 at 01:29:59pm
I flush the rad out the opposite way the water normally flows, its supprising how much crap aomes out.
28th Oct, 2006 at 01:43:08pm
ive changed the temp sender for a new one so its not the guage, i dont have any cool patches in the rad either. The timing is fine but i am getting roughly 40mpg so could it be running too lean? it does run fine other than this problem and no the water doesnt bubble with the cap off n engine revving!
28th Oct, 2006 at 01:54:17pm
its running lean is my guess On 26th Oct, 2004 TurboDave16v said:
4th Nov, 2006 at 12:45:46pm
well i put the thermostat back in today after talking to avon bar. The young lad there suggested using a thermostat blanking sleeve but i never had one. He wasnt completly sure y but what he said was that if you take the thermostat out you end up with a reduced waterflow in cylinders 2,3,4 thus making the engine run hot.
4th Nov, 2006 at 01:46:05pm
A thermostat will not make the engine overheat unless it is stuck shut, and you would know this as the main rad hoses would not get hot. The thermostat is easy to test, put it in a pan of boiling water and you will see it open if it is a good one.
4th Nov, 2006 at 02:21:34pm
thanks for the help tom, confirmed my suspisions it may b small but it purfectly formed
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
4th Nov, 2006 at 03:46:42pm
i had this very same problem, what mine was was, the head studs were not dune up properly to the right torque which caused the water to bubble out the radiator after a good run, anything over 50 mph and the temp would shoot up really quick. check the torque settings on your head studs "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
