| Home > Help Needed / General Tech Chat > Rolling Shell? | |||||||
19th Sep, 2006 at 05:04:13pm
Hi guys, a while back i made a thread about a dilema with my turbo build and me moving away to uni!
Edited by richminiturbo. on 19th Sep, 2006. |
19th Sep, 2006 at 05:13:55pm
If you are going to cut the front off (is that right) and fit a bulkhead box then fitting a scuttle at the same time is not too difficult. It will obviously involve a bit more spraying.
http://www.twin-turbo.co.uk
19th Sep, 2006 at 05:19:26pm
As Wil says - Cut the whole scuttle off, and it's really easy to replace - much more so than trying to make good the repair 'ends' such that the lines are good and they fit well against the rear of the wings.
19th Sep, 2006 at 05:38:50pm
Well i have 2 options really. One is to fix the shell between term times and complete the conversion. And the other is to sell it as it is and buy another mini with a decent shell around next summer and put the turbo engine in that.
19th Sep, 2006 at 06:26:08pm
I have fitted new scuttle ends to both of my minis now and in all fairness i wouldnt bother doing it again if the front end is coming off i would definately fit a whole new scuttle. |
19th Sep, 2006 at 06:27:04pm
I am sure that you could do all the hard work, i.e. cutting off the old scuttle and fitting up the new one. Then see if anybody on here will help you out with the welding or get a mobile welder in to do it. That should keep the cost down and get a good job done. http://www.twin-turbo.co.uk
19th Sep, 2006 at 06:49:07pm
I suppose id be cutting away all shitty metal anyway so its not a loss really, and if i sold it i would lose so much cash!
19th Sep, 2006 at 07:52:26pm
I would cut the front off, but leave the scuttle untill you have a new scuttle in front of you so you know how much to cut off. Also a slightly rusty scuttle is going to protect the car better then no scuttle.
236 Posts Member #: 243 Senior Member Portsmouth |
19th Sep, 2006 at 10:18:27pm
I'd do what Ben H says and leave the scuttle but take the front end off, then when ya get back start on the scuttle.
WooHoo Passed it's MOT!!!! One of the cars in The Portsmouth Mini Turbo Massive!!
19th Sep, 2006 at 11:34:49pm
20th Sep, 2006 at 12:37:43am
Well thanks for the advice guys its much appreciated!
20th Sep, 2006 at 08:11:27am
Id go for a flip front, alot cheaper than new panels and it wont rust.
