| Home > Help Needed / General Tech Chat > Crusty Old Mini Electrics | |||||||
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
20th Sep, 2006 at 08:41:50am
The car is very nearly ready to go for it's MOT. But i can't get the damn indicators to work. Until a few days ago the hazzards worked, but no indicators, but now both have failed.
Site Admin 6297 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
20th Sep, 2006 at 08:52:24am
check the other flasher unit in the engine bay |
20th Sep, 2006 at 09:02:43am
which one is that? and what does it look like? |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
20th Sep, 2006 at 09:19:20am
well, mine is about the same size as the other one, but a square/rectangle rather than round. should be about an inch or two from where you found the other one..... unless of course you havent got one, which could be why your indicators arent working And on the 7th day........... God created turbochargers! |
20th Sep, 2006 at 09:35:05am
mine is square, and sits next to the wiper motor in the engine bay.
20th Sep, 2006 at 09:38:05am
ditto....
20th Sep, 2006 at 10:39:59am
Check out the hazard light switch in the dash. All the indicator wiring runs via this switch, if the contacts inside it are corroded or dirty nothing will work.
20th Sep, 2006 at 11:41:36am
i have a spare switch mate
20th Sep, 2006 at 01:10:56pm
I had this problem.
20th Sep, 2006 at 01:40:26pm
That does ring a bell, there are a couple of inline fuses on the bulkhead in the engine bay, I can't remember what they feed exactly but I am sure they have something to do with the indicators.
![]() 2102 Posts Member #: 432 Post Whore Swindon |
20th Sep, 2006 at 03:27:09pm
One is the indicators that goes to the relay next to the wiper motor, one is for the radio, and my third was always empts so couldny have been anything important lol. shoud be near your carb.
20th Sep, 2006 at 03:56:27pm
Its not a relay, its a flasher unit, there is a difference.
20th Sep, 2006 at 04:02:07pm
you say tomato i say ketchup
20th Sep, 2006 at 04:02:16pm
what if it's a flasher relay?? On 15th May, 2009 TurboDave said:
20th Sep, 2006 at 05:54:02pm
20th Sep, 2006 at 06:05:24pm
On 20/09/2006 17:54:02 Bat said:
Hi, Is the old bi-metalic one a flasher unit, and the electronic type a flasher relay? Cheers, Gavin Hair splitter. Correct Tom Original Picky Bastard & Smug Fucker
20th Sep, 2006 at 06:28:21pm
LOL! VEMs Authorised Installer / Re-seller. K head kits now available!
20th Sep, 2006 at 06:37:54pm
can you not swap relays over just to test Crystal Sound Audio said:
20th Sep, 2006 at 09:49:14pm
Corossion on the indicator bullit connectors, stopped my indicators at the front working though the flasher was going mad. On 26th Oct, 2004 TurboDave16v said:
21st Sep, 2006 at 01:12:51pm
best way to check that you've got a closed circuit is to bridge both relay connections with wire, the lights should stay on.
21st Sep, 2006 at 01:32:10pm
That makes a lot of sense. Good plan. :)
