| Home > Help Needed / General Tech Chat > Decompression Plate | |||||||
12 Posts Member #: 1275 Member |
7th Oct, 2006 at 10:32:18am
I've been thinking of uprooting my 649 cam and going turbo on my 1275 but the other limiting factor is the powermax KA2079r flat top pistons.. They are squeeze cast & hold up well to abuse.
7th Oct, 2006 at 11:13:39am
These are very bad ways of lowering the compression.
7th Oct, 2006 at 01:42:02pm
You can get plates from vmaxcart if you must
7th Oct, 2006 at 05:59:49pm
you should be able to get a fair bit machined out of the head, probably enogh to get the compression down enuogh.
8th Oct, 2006 at 03:02:10am
arrggh!! i didnt think it was that bad..
8th Oct, 2006 at 10:00:58am
Try to find as much CC in the head chamber as possible and/or fit dished pistons.
8th Oct, 2006 at 11:50:34am
8th Oct, 2006 at 12:18:34pm
yep unlessthe heads been skimmed loads tou should be able to find enough in the chambers,
8th Oct, 2006 at 01:16:48pm
Get a new set of pistons and hone the bores. You need to take the engine out and gearbox off to change the camshaft anyway. Do it properly. This will not be much more expensive than to have a silly decompression plate made either. On 13th Jul, 2012 Ben H said:
8th Oct, 2006 at 04:52:06pm
My last N/A engine had 11cc in the pistons and 15cc in the head.
9th Oct, 2006 at 03:36:03am
thanks for the advice gents..
