| Home > Help Needed / General Tech Chat > how do i adjust the fuel mix? | |||||||
17 Posts Member #: 1294 Member Bristol |
8th Oct, 2006 at 01:27:03pm
hi
8th Oct, 2006 at 01:30:29pm
take it to a good RR. where are you located? Edited by iain on 8th Oct, 2006. |
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
8th Oct, 2006 at 01:30:56pm
looking from the front of the car, the carb will have all the fuel hoses on the left hand side of the carb, just bellow and back abit there is a hole, this wil have a screw in it for adjustment of the mixture. if the screw the screwdriver away from you you will lean it off, i recomend only doing this 1/4 turn at a time. but a rr is the best bet so not to melt stuff "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
8th Oct, 2006 at 01:37:46pm
yeh i only need to turn it down enough so it stops turning anything behind me black. im gonna RR it next time i go to college.
8th Oct, 2006 at 01:42:34pm
What spec is the engine and what boost you running? as the plugs will be different. |
8th Oct, 2006 at 02:07:40pm
i wouldnt fiddle unless you know what your doing... especially with a lot of boost.
8th Oct, 2006 at 04:08:17pm
im running it at 4psi until i fit a few more bits and bobs to make it reliable (copper head gasket, electric ignition etc)
8th Oct, 2006 at 04:25:54pm
On 8th of Oct at 04:08pm Arun said:
anyone can reccomend a better place in the area? (bristol) You'll be lucky, the best I've found "locally" is Mech Repairs up in Cheltenham, they're not fans of SU carbs, but they do know their arse from there elbow. Edited by Rob H on 8th Oct, 2006. Isambard Kingdom Brunel said:
8th Oct, 2006 at 04:48:00pm
weld a narrow band sensor in the downpipe and adjust till you get .8volts on idle,Have a drive around and make sure the voltage don't drop below .6
8th Oct, 2006 at 05:22:21pm
Is it defo overfuelling and not spark related ???
Edited by stevieturbo on 8th Oct, 2006. 9.85 @ 145mph
8th Oct, 2006 at 07:33:25pm
8th Oct, 2006 at 07:51:57pm
have you checked fuel pressure? no longer a series, but still 1.3 turbo.
8th Oct, 2006 at 11:20:27pm
its already got sensor for voltmeter, i just need to get a dial/gauge. will do shortly
19 Posts Member #: 1293 Member Yorks |
9th Oct, 2006 at 03:43:14pm
If it's over fuelling that badly doubt that it's just mal adjusted float valve would be a good place to start and check fuel pressure obstructions in the fuel return line etc. As Bat points out it might not be too much fuel but too little air, check intake hoses & filter too. Also oil in the carb dash pot, a fluttering dash pot that does a lovely impression of a misfire when you try to accelerate. |
9th Oct, 2006 at 06:45:15pm
ok, thanks. ill try cleaning the carb tomorrow.
9th Oct, 2006 at 07:46:21pm
On 9th of Oct at 06:45pm Arun said:
ok, thanks. ill try cleaning the carb tomorrow. if that fails im considering ordering an electric ignition system. are these any good/compatible with turbo's? its one that does away with points and the distributor in favour of a coil pack like in modern cars. Do a search on here for megajolt, and you should find loads of information. |
9th Oct, 2006 at 07:49:08pm
other thing to check is for a sticking choke |
9th Oct, 2006 at 08:24:55pm
On 9th of Oct at 07:49pm iain said:
other thing to check is for a sticking choke ![]() cool. i work for ford, and coincidently i 'aquired' a focus coil pack today 8-) i dont think its the choke as the revs drop when i let off choke |
10th Oct, 2006 at 10:18:32pm
sorted it now |
i just had to clean the dizzy cap
