Home > Help Needed / General Tech Chat > Starter Solenoid Current
Does anyone know how many amps a starter solenoid required to trigger it. I'm replacing all the switches on my dash, I want to make sure I get one which will not burn out.
Jim
j_d_jag_mini
Member #: 979
If the Switch you buy is for 12volts you wont have a problem...just dont buy a piddly little one like that used for car alarm kill switches. Something along lines of a lighting switch is a safe bet.
Most generally dont tell you amount of current that they can handle anyways.
Jeremy
1975 MkIII Morris Mini 1300 Turbo, 100bhp...if only it could run long enough to drive it legally!
Dangerous
Member #: 417
3.5 amps to do the square inner wing one,just measured it
Magic, thanks Brian, 5amps should do it then!
Are you sure about the current of the solenoids. Its a hefty wire, something like 2.5mmsqr, well on the pre engaged it is, and fed with a relay itself.
Id recon at least 10 amps?? for the pre engaged.
Inertia solenoid, well you may be right, thinking about it. Theres no mechanical load on it.
Dangerous
Member #: 417
The pre engaged ones turn the starter slowly and have a solinoid to push the cog over,Then the main power goes in.So I expect they take more
The pre-engaged don't turn slowly, but need a lot of current to push the pinion into mesh. Once engaged the current drops right off.
Dangerous
Member #: 417
No they turn slowly,wire one up with jump leads and try it
jimmy
Member #: 829
essex
3amps to 5amps is normal for a solenoid with a charged battery
1293 Turbo mini
