Page: |
Home > Show Us Yours! > 7 porter progress, Engine build Number....seven?? ....now K1200 | |||||||
4th Nov, 2006 at 11:38:46pm
Done a bit more today,
Edited by Joe C on 4th Nov, 2006. On 28th Aug, 2011 Kean said:
520 Posts Member #: 189 Post Whore Norway |
5th Nov, 2006 at 12:56:54pm
Nice :) www.shag.no |
5th Nov, 2006 at 05:36:03pm
Cheers Vegar,
784 Posts Member #: 912 Post Whore North Yorkshire |
5th Nov, 2006 at 05:51:15pm
Looks proper and ment to be that.!
I drill holes in everything..! |
31st Jan, 2007 at 09:26:52pm
Right, after considerable slacking recently i'm about to push on with this, I had come to a bit of a dead end due to not quite being able to fit the fuel rail under the bonnet, I remember Dars also had this problem with his so my solution may be of use to him also.
31st Jan, 2007 at 09:32:37pm
Oh also regarding the injectors, smaller ones can be found in a number of fiats (Brava's, barachetta's, belingos ect) and in some bikes. but i went for some after market ones.
223 Posts Member #: 598 Senior Member Gaol |
31st Jan, 2007 at 10:08:24pm
My CBR 600 injectors are pico versions too, just not too sure on the flow rates?
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off... |
31st Jan, 2007 at 11:16:05pm
I can't help with the CBR injectors but i do have a PDF with what injectors are used in what model car covering itallian cars.
31st Jan, 2007 at 11:54:06pm
have you got somewhere you can morror it off?
1st Feb, 2007 at 11:11:09am
I'll email it over when i get home from work, it lists all the electrical engine parts also, coils sensors ect. On 28th Aug, 2011 Kean said:
Site Admin 9401 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
1st Feb, 2007 at 11:40:30am
good work, keep us posted! what ECU will you be running? Team www.sheepspeed.com Racing
1st Feb, 2007 at 01:01:33pm
Megasquirt,
10th Mar, 2007 at 09:25:37pm
Looks like I have finally got the fuel rail sorted!!
Edited by Joe C on 10th Mar, 2007. On 28th Aug, 2011 Kean said:
11046 Posts Member #: 965 Post Whore Preston On The Brook |
10th Mar, 2007 at 09:33:15pm
Looking really good there bud On 26th Oct, 2004 TurboDave16v said:
9311 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
11th Mar, 2007 at 01:01:18am
thats looking like a good tidy solution!
11th Mar, 2007 at 01:17:55am
well i don't know about looking good or being tidy....
11th Mar, 2007 at 07:28:21am
Looking like a nice setup that!
11th Mar, 2007 at 11:54:32am
innovative Crystal Sound Audio said:
902 Posts Member #: 111 Post Whore Loughborough |
11th Mar, 2007 at 12:04:50pm
I want a 7 port...... a boy can dream.... |
11th Mar, 2007 at 05:57:39pm
On 11th of Mar, 2007 at 07:28am Si P said:
Looking like a nice setup that! Have you managed to source the correct length sparkplugs yet.? Also I had a good look at head at MINISPIT the other day, and they look like they almost run horizontal into the chambers to. Very interested in seeing it come together. Si Si, Yes and no, there is a plug the right length from something american, but i reckon its going to be to hot a plug, so instead i'm going to look at counterboring plug hole into the head a bit more so i can use any of the 10mm x 3/4"plugs from large bikes, failing that, i'll look at modding the plugs... other than that a could cut the chamber back toward the plug, but i don't really want to do that as it'll cock the shape up. was the head you looked at a bare casting or a finished head? what cere the chambers like? did the apear to be cut back a lot toward the plug? say in comparison to this... your dead right about the plugs being nearly horizontal, i gues they can only be angled about 10-15 degrees from flat On 28th Aug, 2011 Kean said:
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
11th Mar, 2007 at 06:18:47pm
have a look at plugs for a mondeo V6, tere really long in the thread. turbo 16v k-series 11.9@118.9 :)
11th Mar, 2007 at 06:44:41pm
The mondo plugs are 14mm thread, i need 10mm,
2500 Posts Member #: 648 Post Whore Northern Ireland (ex AUS) |
11th Mar, 2007 at 10:10:49pm
I love these clearance shots, what set the timer on the camera then slam the bonnet down quickly? On 7th Nov, 2008 Nic said:
11th Mar, 2007 at 10:20:57pm
No it's a camera phone, if you look you'll notice there's no grill, wedged my arm in and pressed the button, bit of a squeeze with those spots in the way! On 28th Aug, 2011 Kean said:
11th Mar, 2007 at 10:28:05pm
Beats using bits of blue tac and seeing if it gets squished by the bonnet. On 7th Nov, 2008 Nic said:
Page: |
