| Home > Help Needed / General Tech Chat > Stainless Tubing | |||||||
48 Posts Member #: 1244 Member Bagshot, Surrey |
17th Oct, 2006 at 08:43:18pm
If I was to manufacture my own manifold to fit a T" turbo what grade stainless is recommended 303, 304 or 316?
809 Posts Member #: 224 Post Whore Katy TEXAS |
17th Oct, 2006 at 08:45:35pm
Check out the miragemotorsport web site
Edited by Brocky on 17th Oct, 2006. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
17th Oct, 2006 at 08:55:48pm
321 is the correct grade for turbo manifolds. On 15th May, 2009 TurboDave said:
17th Oct, 2006 at 09:08:51pm
304 will suffice, but not as robust as 321. 316 - forget it!!!
17th Oct, 2006 at 09:11:11pm
Does it really matter what grade ????
17th Oct, 2006 at 09:40:09pm
What about size's? |
1425 Posts Member #: 690 Post Whore Norfolk |
17th Oct, 2006 at 09:44:27pm
check out Milner Offroad's website - some very reasonable mandrel bends/tubng on there. If Carling made Mini engines
18th Oct, 2006 at 02:48:53am
On 17th of Oct, 2006 at 09:11pm stevieturbo said:
Does it really matter what grade ???? I was under the impression, the higher grades tend to crack easier ?? It won't matter one iota on a nat-asp motor, but if you ever have your manifold even slightly glowing, then the only stainless that will do the job (again and again) for a turbo setup is 321. I understand 321 to have lower carbon than 304 and is supplemented by titanium to make for the ultimate in high-temp tubing. There is another grade similar to 321 - but don't recall what it is but 321 is easier to find.
304 will suffice in most cases (so long as it's genuine quality 304 - or even better 304L) however, and is a lot easier to find. 316 will crack and scale after a few serious heat cycles - probably lasting twice, maybe three times longer than plain steel (which isn't very long at all)... Jimsters manifold is made of 321 - and was even Tigged together without back-purging or using solarflux. So far so good! Edited by turbodave16v on 18th Oct, 2006. On 17th Nov, 2014 Tom Fenton said:
18th Oct, 2006 at 09:09:48am
abd believe me, it did glow on the rollers!! On 15th May, 2009 TurboDave said:
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
18th Oct, 2006 at 12:26:18pm
Jim, have you got any vids of it on the rollers online yet? |
18th Oct, 2006 at 02:05:24pm
I didn't take any video's or photo's of it on the rollers.
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
18th Oct, 2006 at 10:22:55pm
U should have said that you were gonna be up my neck of the woods i would have come down for a look. Only live 15mins down the road from Dave Walkers workshop!! |
19th Oct, 2006 at 07:54:51am
I'll give you a shout next time I'm up at daves, will be about christmas time I guess On 15th May, 2009 TurboDave said:
19th Oct, 2006 at 08:23:31am
I will look forward to the next issue of PPC landing on the doormat at Spannerbitch HQ even more than usual then!
19th Oct, 2006 at 08:23:58pm
I made my RV8 manifolds from plumbers black iron pipe lol
19th Oct, 2006 at 10:01:41pm
Anyone every made a Titanium manifold? if so was it / is it any good? |
19th Oct, 2006 at 10:24:07pm
Not heard of people using it, the main super material is called Inconel and is used on f1 exhausts. It can easily take red hot temps and apart from being £7000 for a f3 manifold its good stuff!! |
19th Oct, 2006 at 10:28:26pm
Incol does the trick, use it a lot of work... hmm.... |
