| Home > Help Needed / General Tech Chat > Exhaust Gaskets | |||||||
51 Posts Member #: 979 Advanced Member Auckland, New Zealand |
24th Oct, 2006 at 08:52:17am
Hey all me again !
1975 MkIII Morris Mini 1300 Turbo, 100bhp...if only it could run long enough to drive it legally! |
24th Oct, 2006 at 04:46:39pm
The problem you have is the exhaust
24th Oct, 2006 at 04:55:02pm
As ben says - a straight edge revealls all kinds of woes.
Edited by turbodave16v on 24th Oct, 2006. On 17th Nov, 2014 Tom Fenton said:
25th Oct, 2006 at 06:12:43am
Thanks guys, I had the manifold machined earlier this year but they only did the turbo end...i never thought to bother about the other end at the time as it looked sweet. I was hopeing to not have to pull it all apart again but looks like i will have too !
26th Oct, 2006 at 01:54:17pm
While your at it i would port the ex manifold and turbo elbow
26th Oct, 2006 at 05:38:46pm
I assume you are using a proper "turbo" gasket in the first place ???
26th Oct, 2006 at 05:44:58pm
use teh injection ones ive never had one fail yet they are the dogs always looking for them bigger bunches of bannanas |
26th Oct, 2006 at 06:00:47pm
From looking at the Minispares site recently when someone linked head gaskets
27th Oct, 2006 at 09:49:56am
Um the gaskets i have been using are the wide verson and similar of what you would normally find on any 1275 or 1000cc.
27th Oct, 2006 at 01:02:56pm
leave the 2 dividers in the manifold
Edited by BENROSS on 27th Oct, 2006.
27th Oct, 2006 at 04:31:31pm
On 27th of Oct, 2006 at 09:49am j_d_jag_mini said:
There are no steel rings around exhaust ports.....sounds like im using totally the wrong type of gasket ? ! Thanks Quite correct...you are. Exhaust ports should have a steel ring around them for a turbo car ( and efi as it seems ) 9.85 @ 145mph
27th Oct, 2006 at 09:52:43pm
Thanks guys,
28th Oct, 2006 at 02:09:08am
Something like this....
28th Oct, 2006 at 04:22:11am
http://www.minispares.com/images/products/...GUG704063MG.jpg
28th Oct, 2006 at 12:39:42pm
I see they are a different material from the original turbo gaskets ?? 9.85 @ 145mph
28th Oct, 2006 at 02:01:08pm
Dunno. These are the same ones I've only ever used since I got into 'turbos'...
28th Oct, 2006 at 06:20:12pm
28th Oct, 2006 at 06:33:54pm
pic of an original metro turbo gasket along side some flanges I had cut 9.85 @ 145mph
