Home > Help Needed / General Tech Chat > Electronics help, please
I've got a V8 rev counter in my Mini, which surprisingly reads half speed! *wink*
Is there some kind of electronic gizmo I can build that will double the number of pulses from the Rev counter output on my ECU?
Please don't say change the rev counter!
Edited by Bat on 1st Nov, 2006.
Carl
Member #: 95
liverpool-on-sea
might seem sily but check its not got a switch on the back for 4,6 or 8. if it hasnt and youve already checked then i appolgise for stating the obvious
Carl .. I know the one you mean, unfortunately no :(
erm yeah probably,
you can make a simple frequency doubler with some diodes and small transformers ( similar to synth ring moduators)
have a read of this.
http://www.wenzel.com/pdffiles/diodedbl.pdf
