Home > General Chat > Nibbler
Dangerous
Member #: 417
Got to get one,prob from machine mart.Which one works best air or the in the drill one both about £40
Or has any one tryed the £20ish air ones of ebay*oh well*
Edited by Dangerous on 1st Nov, 2006.
evolotion
Member #: 83
Glasgow, Scotland
whichever one you get mate, keep it oiled!
Denis O'Brien.
i used an air one a fair bit, cracking bit of kit
I've got one that goes in the end of the drill, had it donkeys years no problem.
Only thing I would say against it is that it's a bit tricky to use as you've got to hold the drill, the nibbler attachment and what you're cutting!
Ben H
Member #: 184
Melton Mowbray, Pie Country
I have one for the drill too and bat is spot on there. Works best if you can clamp the nibler and move the metal. Obviuosly not possible if the thing you are nibbling is part of a shell though.
http://www.twin-turbo.co.uk
Dr. jinG
Member #: 368
Roseville, CA (USA)
Great timing. I was reviewing a catalog with these, and there were options for drill, air, and electric. Air was most expensive, and I really see no reason to go that route, since electric was cheaper, cuts the same thickness/hardness, and you have a MUCH smaller diameter danglie of the back to deal with. Anyone know why you'd go pneumatic? Is it self-oiling, maybe?
If I could, I'd get you one cheaper from here, Dangerous, but I can't... :(
1967 Cooper 's' Turbo build @ www.drjing.com
antman
Member #: 358
Snetterton, Norfolk
Yeah i use an air one a lot at work from machine mart. Just make sure that you oil down the fitting before use and make sure the stuff you are cutting isn't too thick *oh well* Or else you may kill it!!
nutter driver
Member #: 47
Not very sunny swanage
not much help really, but ive got a 110v one that i aquired with a load of other 110v tools in a bulk lot, and its awsome. did wonder about an air powered one, but tbh it would have to be preety good to live up to the one ive got....
Dangerous
Member #: 417
Thinking air then,so if I want to cut a little plate out I can hold the plate in one hand and nibbler in the other.
P.s. That is one reason why I bought 2 smallish compressors and joined them together to be more portable
