Home > Help Needed / General Tech Chat > Stock 1275 Turbo Dish volume ?
Brocky
Member #: 224
Katy TEXAS
Just a quick couple of questions
Whats the dish volume of the stock turbo piston, and how much can you take off the deck without turning down the crown, if any ?
Cheers Brocky *smiley*
Dangerous
Member #: 417
12cc
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4605
Brocky
Member #: 224
Katy TEXAS
Thanks man *smiley*
Ok assuming the block hasn't been touched whats the :
1). Standard turbo ring land volume.
2). The standard turbo deck volume.
Did search but nothing under ring land
Wheres the best place to get hold of a burrettor ? I can get hold of a graduated syringe , will this be good enough ?
Brocky
Edited by Brocky on 20th Nov, 2006.
Brocky
Member #: 224
Katy TEXAS
Just looking through some old posts,
It seems the deck volume is quite small = <1cc? as the turbo crown sits higher than the NA 1275 A+ piston.
So in terms of getting a good gasket surface on the block, definately just a flash of the top of the block or the pistons will need turning down.
How much would a surface grind take off ?
Is the ring land volume about 0.78cc for the turbo piston ?
I am just trying to work out what I need in the head chamber and how much to take off the block to get it nice and flat.
Your comments and experience would be appreciated...
Looks like 26cc in the head will give me 8.5:1 cr with stock 1275 turbo setup. ??
Cheers brocky
