Home > Help Needed / General Tech Chat > Megajolt Rev/tacho
Im currently sorting my loom out for MJ, but have just realised the pin for the tacho is missing. Ive read this thread
But im still a bit unsure if you can just drill the blank pin and connect it direct or if you have to connect diodes aswell?
What is the 'Tacho out' for on the molex connector? will that give an output for the tacho instead?
MAtt
Ben H
Member #: 184
Melton Mowbray, Pie Country
Just drill it out and connect it directly to the tacho. However, it does not work on all rev counters, but without trying you won't know.
If it does not work then you have to go down the diode route.
http://www.twin-turbo.co.uk
Nice one i'll try that, I made the school boy error of already taping my loom up!
Duh!!
JT
Member #: 637
Hertfordshire
do you think a classic smiths style revcounter work with MJ?
or are they all differnt?
cheers
josh
My build thread..
Which bit of the above don't you understand??????????????????*indifferent*
JT
Member #: 637
Hertfordshire
i was wondering weather somone has tried using a classic smiths revcounter with megajolt, and could say if it worked or not?
thought it would be good to know before buying one!?
My build thread..
miniminor63
Member #: 672
The oversills police
Oslo, Norway
if the rev counter is fine with a square 12V wave it will be fine with the EDIS signal. I dont know how the signal from the megajolt box behave, but it is probably not more voltage at least...
jamesfawcett
Member #: 218
Bingley, West Yorkshire
My smiths one didnt work with megajolt. The diode thing doesnt look too hard though.
Im planning on a small screen now with the new megajolt software with the dials
if it helps , the mega jolt output for tach ,works on my mini tach !
Ben H
Member #: 184
Yes, the standars rev counter from the three dial dash works a treat.
A pall of mine had a few problems getting his working and ended up converting his to 2 cylinders and driving it off just one of the coils. There are plenty of ways to get things working.
shane
Member #: 1246
Lowestoft, Suffolk.
Anyone used a Tim gague with MJ, just for my reference?
Shane
ive tried and failed
Bugger thats what ive got!!!
I think it can run 2 4 or 6 cylinder though so I should be able to tap off the coil and set it to two cylinders, fingers croosed!
