Home > Wanted > long clutch arm
jamesfawcett
Member #: 218
Bingley, West Yorkshire
I need a long clutch arm, and do i need any brackets too, just to bolt my clutch slave cylinder onto a metro turbo engine.
thankyou!!
james
right,
the mutro is verto so needs the short arm.
did the engine in the mini before have a long arm?
If so it could mean you have the wrong slave fitted.
Do you mean a pre-verto arm or do you mean one of the Metro arms which are used with a cable clutch? If it's the later I've got one you can have as it's no use to me.
jamesfawcett
Member #: 218
a pre verto arm is what i need i think
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=127403
anyone got one i can buy?
Long arm will NOT work with a verto clutch as fitted to ALL metro engines.
Full stop.
Manchester minis.
Technical
Clutch troubleshooter
enough said.
