Home > General Chat > Minisport Pistons
http://www.minisport.com/classic-mini-shop...20-product.html
are they any good? very cheap...
Anyone have any idea what sort of dish could be machined into them?
jimmy
Member #: 829
essex
What for turbo use ?
1293 Turbo mini
well yeah?
if these are genuine rover pistons these will make the grade
you could reduce the compression ratio via the route of the combustion chamber to get to a sane level for turbo application performance wise
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I would love to see the postage on that, last time I ordered an indicator/wiper stalk assembly from Minisport it cost £21 but I was quoted £35 on postage!?!
On 7th Nov, 2008 Nic said:
naeJ
m
yes minisport you have to ask because they are robbers with the postage *frown*
make sure the ring pac is in with the price *wink*
if these pistons are what you want
i have e mailed minisport about the spec of them
will post my findings
Edited by BENROSS on 27th Dec, 2006.
I dont want em, just thought someone on here might...?
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Well if they are Rover items and have the ring pack then they are a bargin to my mind. Obviously only for people like me wanting to do a fairly high comp / low boost build for road manners.
Might order some, might actually be cheaper to get Princess Anne to bring them down for me though, after all she is likely to be passing over New Year... LOL
jimmy
Member #: 829
essex
On 27th of Dec, 2006 at 08:22pm joeybaby83 said:
well yeah?
Sorry joe i was looking on the same line as you they are cheap but what boost are we looking at 10psi or to high because that is the max i was lloking at minispares pistons are around £200 and avon are about £280
1293 Turbo mini
Jimmy .. With 9.4:1 you should be able to squeeze 10 psi in there, as long as it's well setup. Preferably with mapped ignition... Intercooler also essential.
I'm planning on 10 psi into my stock MPi engine...
RogerM
Member #: 1217
Can always take a bit out of the head to get it around high 8s or 9 with easy.
I think that if you know your only planning a torquey motor not a bannana tree they should be ok.
Anybody know how think the crown is???
andeh
Member #: 97
Near Daventry, midlands
i'd put money on them being hepolite 21250's, which if memory serves are std non MG 1275 pistons?
Edited by andeh on 28th Dec, 2006.
jimmy
Member #: 829
essex
If so that is a no no because i have a mg metro engine with std pistons in it
1293 Turbo mini
jimmy
Member #: 829
essex
thanks
1293 Turbo mini
jonnyd64
Member #: 631
Thames valley
If your not into big bananna`s and you haven`t alot of money,a cheap fun engine of around 8 psi , i`d go for it. To lower the compression use two head gaskets , a+ head studs or ARP (BETTER) .
Think about it your not on boost all the time....
Intercooler is a cheap insurance ....
Im running two head gaskets with ARP studs ( and was told it wouldn`t work , don`t do it etc) but it lowered compression and has worked .Avonpark 2005 , Saxo, corsa scoobies hunting on a saturday night....lol.
Untill i can afford a good t-head it is a cheap option and im on the road in stead of in the garage dreaming.....
Or worse still ...having to sell my dream....
I know , i know im sorry , it just makes me grin !!!
Intercooled 1293 cc Turbo +
March 06,4psi and counting .
Its now gone up to 8psi.
Nov 06,10psi +.
And now part of the Airbourne club.
