Home > Help Needed / General Tech Chat > Lean On Acceleration
colas
Member #: 102
Pennsylvania USA
This problem has just started. If it's at idle (Around 800RPM) and I try to set off or even if I just hit the accelerator pedal the Air/Fuel gauge goes way lean and the engine tries to stall and backfires from the carb. I have replaced all pipes and fuel filter. When it's running and on boost the mixture is good. Any ideas???? It is also running megajolt.
AllanMcD
Member #: 414
Dalbeattie Scotland
Oil in carb dashpot?
Allan
http://www.rabdunn.co.uk/
colas
Member #: 102
Pennsylvania USA
Yes That was the first thing i checked. I have always used engine oil.
Could be an air leak in the carb / manifold area. You'll lose this under boost as you've got pressure and not vacuum, hence the mixture is correct.
Check all vacuum hoses, breather pipes etc. Then check inlet to carb and manifopld to head gaskets for leaks. You can do this with a can of easy start or similar, but DON'T get any on the exhaust! Engine revs will increase when you spray over the leak.
colas
Member #: 102
Pennsylvania USA
Sorry to sound stupid but whats an American equivelant of easy start. Whats in it?
Lance Link
Member #: 1174
Sunny Southern California, USA
It's mostly made from ether. It's called 'starting fluid' here and I think Gunk makes it. You should be able to get it at the local Pep Boys.
R
61 Austin Seven; building a 1275 'over the clutch' turbo, R5 T2'd, custom intercooled, megajolt electrified, canyon carver
www.motorlust.com - The Online Magazine for Car Guys Like Us
colas
Member #: 102
Pennsylvania USA
Thank You all for your help. I'll try that and hope I find a leak.
Anything that combusts should work, like carb cleaner, brake cleaner ect. Easy start is the best as it's very combustible!
colas
Member #: 102
Pennsylvania USA
I'll try not to blow my self up!!!
colas
Member #: 102
Pennsylvania USA
OK I have tried the easy start and the engine note never changed. I sprayed it everywhere. Any more ideas??
So much for the theory :(
The only other thing I can think of is the piston in the carb is rising too fast giving a weak mixture.
I'd suggest heavier oil or a stronger spring, but this doesn't explian why it's just started doing it.....
colas
Member #: 102
Pennsylvania USA
I'll pull the dashpot off and have a look at the spring. I use 20/50 engine oil in the dashpot. Seems what most are using.
