Home > Wanted > piston rings
fordimus maximus
Member #: 1357
telford,shropshire
if anyone has them new or know where i could get them from for cheaper than £80 it would be much appreciated.
im desperate!!!!!
please
thanks jamie
Richie
Member #: 628
for which pistons ? i know that the standard 1275 turbo rings for the 20831 piston is now obsolete :(
Edited by Richie on 8th Jan, 2007.
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
fordimus maximus
Member #: 1357
telford,shropshire
yeah they are for those, so if there are obsolete, where do i go from here?
Someone on this site has a local engine builders that can get them. Unfortunately I don't know who :(
mattyking
Member #: 873
Thatcham, berkshire
hhmmm i recently bought some piston rings for my turbo. standard 1275 i wasnt awear they had stopped selling them i got them easy next day dilivery. i will check with my dad as he nos about it im not the mechanic and ill let you no dude. all i no about my engine is its standard 1275 a plus with the orignal pistons.
fordimus maximus
Member #: 1357
telford,shropshire
ok cheers jockey.
Richie
Member #: 628
two pistons were made for the turbo engine, the ringsets are different...if ure pistons are turbo ones and the ones i mentioned, i would appreciate the address so i can get some before they get bought up ?
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
fordimus maximus
Member #: 1357
telford,shropshire
ok ill sort the adress and number out for ya.
AL
Member #: 1347
Croydon (South London)
Any chance you could pm me the details too? I need some rings for 20831A pistons too. Cheers, AL.
in what way do these ring pack differ from the standard MG ring pack, has anyone acctually measured the ring grooves??.
carl
I'm no expert on this, but I seem to remember from another post the oil control ring is a bit wider.....
fordimus maximus
Member #: 1357
telford,shropshire
yeah i think they are either 3mm or 4mm
bit vague here dont you think, a difference of nearly 0.040".
if you styill have the oil scraper spring spacer you should be able to use the standard MG rings surely,
