| Home > FAQ / Knowledge > Mjlj - tps or map ??? | |||||||
4 Posts Member #: 1443 Junior Member |
10th Jan, 2007 at 12:47:40am
hi folks.....
10th Jan, 2007 at 12:49:18am
i meant Crank pulley not flywheel ...............Doh! |
10th Jan, 2007 at 12:57:50am
MAP is better for forced induction and road driven (linked port / manifold runner) engines.
567 Posts Member #: 102 Post Whore Pennsylvania USA |
10th Jan, 2007 at 12:58:07am
For a turbo motor MAP is best.
Edited by colas on 10th Jan, 2007. |
10th Jan, 2007 at 01:00:20am
Dam roger you beat me to it by 17 seconds. LOL |
10th Jan, 2007 at 01:03:33am
Not normally my propblem ..... honestly ... who have you been speaking too .... she's a liar!!!
Edited by RogerM on 10th Jan, 2007. Every day is a school day ...........
10th Jan, 2007 at 01:29:49am
MAP is best in theory; but TPS does work very well.
10th Jan, 2007 at 01:50:40am
10th Jan, 2007 at 02:50:46am
Huh? I have TPS and crank, with a map sensor as a compensation.
10th Jan, 2007 at 06:33:10am
yes, its either only TPS or only MAP |
1171 Posts Member #: 107 Post Whore Sunny Sussex |
10th Jan, 2007 at 08:32:20am
just dusting off my MegaSquirt... is the MSquirt a TPS OR MAP system too, as the TPS bracket was causing me hair loss trying to design and fit one.
10th Jan, 2007 at 12:08:59pm
I am more into VEMS, but I THINK the squirt has provision for both at the same time |
10th Jan, 2007 at 12:44:48pm
MS2 uses throttle position and MAP together, useful for light throttle under boost conditions. Not sure about MS1 though as I have only ever run those alpha-n (TPS and revs only) on cars with a throttle per cylinder. Every day is a school day ...........
10th Jan, 2007 at 02:23:24pm
On 10th of Jan, 2007 at 06:33am miniminor63 said:
yes, its either only TPS or only MAP Ah - If this MegaJolt system is indeed one, or t'other; then a turbo motor clearly needs rpm vs MAP. I didn't realise it was that basic of a system to be honest. On 17th Nov, 2014 Tom Fenton said:
10th Jan, 2007 at 04:36:14pm
Yup its basic TD - but its cheap as chips!
AlexF |
10th Jan, 2007 at 05:14:20pm
Oh yeah - I wasn't dissing it. For the money, it's well worth it I guess. And is a big step-up from a dizzy....
Edited by turbodave16v on 10th Jan, 2007. On 17th Nov, 2014 Tom Fenton said:
10th Jan, 2007 at 05:31:46pm
So ideally you want to run TPS with Map compensation?
10th Jan, 2007 at 06:07:25pm
Ideally - you want to run Map vs RPM with TPS compensation...
10th Jan, 2007 at 06:23:49pm
Yes I run it on mine... not that any are on the road at the moment!
AlexF |
